Solve Clairaut's Equation: Find Singular Solution
  • MHB
  • Thread starter Suvadip
In summary, the conversation discusses finding the singular solution of Clairaut's equation, which is a differential equation. The equation is given in terms of p and involves square roots. The speaker has made some progress and can express the solution in parametric form, but is unsure if it is necessary to express it in implicit form. They provide a parametric form for the solution.
Suvadip
74
Please help me to find the singular solution of the following Clairaut's equation
\(\displaystyle y=px+\sqrt{1+2p^4}\) where \(\displaystyle p=\frac{dy}{dx}\)
suvadip said:
I can express as x=f(p) and y=g(p). But I can't eliminate p to find a relation between x and y.
Is it necessary to express the singular solution in implicit form?. You can write it in parametric form: $$x=\dfrac{-4p^3}{\sqrt{1+2p^4}},\quad y=\dfrac{1-2p^4}{\sqrt{1+2p^4}}$$
To solve Clairaut's equation and find the singular solution, we need to first differentiate the given equation with respect to x. This gives us:
p = p + x(p) + \frac{2p^3}{\sqrt{1+2p^4}}\frac{dp}{dx}
Next, we can simplify this equation by rearranging terms and isolating the derivative term:
\frac{dp}{dx} = \frac{\sqrt{1+2p^4}}{2p^3}
Now, we can substitute this expression for the derivative back into the original equation and solve for p:
y = px + \sqrt{1+2p^4}
y = px + \frac{2p^3}{2p^3}
y = px + 1
This is the singular solution of Clairaut's equation, as it only contains one arbitrary constant (p) and does not involve differentiation. This solution represents a family of curves that all satisfy the original equation and have the same slope at every point.
In conclusion, the singular solution of Clairaut's equation is y = px + 1.
FAQ: Solve Clairaut's Equation: Find Singular Solution
What is Clairaut's Equation?
Clairaut's Equation is a second-order differential equation that can be used to model a variety of physical and mathematical systems. It is named after the French mathematician Alexis Clairaut who first studied it in the 18th century.
How do you solve Clairaut's Equation?
To solve Clairaut's Equation, one must first rewrite it in its standard form and then use a variety of techniques such as separation of variables, substitution, or integration to find its general solution. In some cases, a singular solution may also be found by setting a constant equal to zero.
What is a singular solution?
A singular solution is a solution to Clairaut's Equation that does not follow the general solution but rather has a unique form. It is usually found by setting a constant equal to zero, and it can represent a special case or boundary condition for the system being modeled.
Can Clairaut's Equation be used to model real-world systems?
Yes, Clairaut's Equation can be used to model a variety of real-world systems such as the motion of a pendulum, the shape of a hanging chain, or the behavior of a vibrating string. It is a versatile equation that can be adapted to fit different scenarios.
Are there any limitations to using Clairaut's Equation?
While Clairaut's Equation can be used to model a wide range of systems, it does have some limitations. For example, it assumes that the system being modeled is continuous and differentiable, and it may not accurately predict behavior in cases where these assumptions do not hold.
