MHB Solve Complex Number IV Problem: Find Radius & Centre
The discussion focuses on finding the radius and center of a circle represented by the complex number w in an Argand diagram, where the real part of w is zero. The expression for w is given as w=(z+1)/(z-2i), and participants are working through the manipulation of this equation to isolate the real part. After performing the necessary calculations, it is established that the condition Re(w)=0 leads to the equation x^2+x+y^2-2y=0. The goal is to transform this equation into the standard circle form (x-a)^2+(y-b)^2=r^2 to determine the circle's parameters. The discussion emphasizes the importance of correctly calculating and rearranging the equation to identify the center and radius of the circle.
Punch
A complex number is represented by the point P in an Argand diagram. If the real part of the complex number w=\frac{z+1}{z-2i} (z not 2i) is zero, show that the locus of P is a circle and find the radius and centre of the circle.
I have a problem manipulating w to find the real part of w
Mathematics news on Phys.org
Hi Punch,
Let \(z=x+yi\) where \(x,y\in\Re\).
\[w=\frac{z+1}{z-2i}=\frac{(x+1)+yi}{x+(y-2)i}\]
Now multiply both the numerator and the denominator by \(x-(y-2)i\). Hope you can continue. :)
Sudharaka said:
Hi Punch,
I followed as you said but couldn't find how to extract the real part out...
What did you get after multiplying by \(x-(y-2)i\) ?
With regards to the real part, \frac{x^2+x+y^2+2y}{x^2+y^2-2y+4}=0
But I do not see how i can use this
Punch said:
With regards to the real part, \[\frac{x^2+x+y^2+2y}{x^2+y^2-2y+4}=0\]
\[Re(w)=\frac{x^2+x+y^2-2y}{x^2+y^2-4y+4}\]
As you may see, you have calculated the real part incorrectly. Check your calculation again.
Since, \(Re(w)=0\Rightarrow x^2+x+y^2-2y=0\)
Now can you try to transform this equation into the form \((x-a)^2+(y-b)^2=r^2\). The complex number \(z\) is on this circle. All you got to do is find \(a, b\) and \(c\).
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
