Solve Continuity Problem: Find a and b | Homework Help
  • Thread starter realism877
  • Tags
    Continuity
In summary, to make the function continuous everywhere, you need to calculate the left-sided limits and right-sided limits at 2 and 3, and make sure they are equal to the values of f(2) and f(3). However, there is no solution that can make the function continuous at x = 2, unless there is a typo in the given function definition. The values of a = 1/2 and b = 1/2 make the function continuous at x = 3, but there are other combinations of a and b that also make the function continuous at x = 3.
realism877
80
I have to find out what a and b is to make it continuous everywhere
((x)^4-4)/(x-2) if x<2a(x)^2-bx+3 if 2<x<3
2x-a+b if x greater than or equal to 3
I don't know what I'm doing to solve this problem.
Hi realism877, :smile:
A function f is continuous in a if and only if [tex]\lim_{x\rightarrow a}{f(x)}=f(a)[/tex]. In particular, the right-sided limit must equal the left-sided limit.
So, in your example, you must calculate the left-sided limits and the right-sided limits in 2 and 3 and make sure they are equal to f(2) and f(3)...
First of all, f(x) is undefined at x=2 and x=3 .
Once the above is fixed, you will need [tex]\lim_{\,x\to2^-}f(x)=\lim_{\,x\to2^+}f(x)=f(2) [/tex] and [tex]\lim_{\,x\to3^-}f(x)=\lim_{\,x\to3^+}f(x)=f(3) \,.[/tex]
Usually for these questions, you need to make sure that the limits on both sides are the same. e.g 0.00001 and -0.0001 don't jump i.e limit does not change
Is a=1/2 and b=1/2?
No, f(3) is defined as 6- a+ b. But you are right that the way the problem is given f(2) is not defined and no values of a and b will make the function continuous there.
realism877 said:
Is a=1/2 and b=1/2?
Why are you asking? Do you know what "continuity" means? If a= 1/2 and b= 1/2 will this function satisfy the definition of "continuity" at x= 2 and x= 3.
I know what coninuity means, but we are asked to to solve for a and b.
I did that and I got those values.
Can't you somehow turn this into a system of equations with 2 unknowns and then use substitution/elimination to solve a/b ?
I did that. I just want to know if I'm right.
A=1/2 b=1/2
realism877 said:
Is a=1/2 and b=1/2?
Well, that combination does make the function continuous at x = 3 (if you define f(3)=6), but so do many other combinations of a & b. For instance, a = 3/2 & b= 3 makes f continuous at x = 3, if you define f(3) = 15/2 .
The discontinuity at x = 2 is NOT removable - unless there is a typo in the definition of f(x) for x < 2. There is no factor in the numerator to cancel the factor of (x - 2) in the denominator.
FAQ: Solve Continuity Problem: Find a and b | Homework Help
What is continuity in mathematics?
Continuity is a fundamental concept in mathematics that describes the smoothness or connectedness of a function or curve. It means that there are no sudden jumps or breaks in the graph of the function, and that the function can be drawn without lifting the pen from the paper.
How do you solve a continuity problem?
To solve a continuity problem, you need to check if the function is defined at the given point and if the left and right limits of the function at that point are equal. If both conditions are met, then the function is continuous at that point. If not, you may need to use algebraic techniques, such as factoring or simplifying, to make the function continuous.
Why is continuity important in calculus?
Continuity is important in calculus because it allows us to analyze the behavior of functions and their graphs, and to make predictions about their values at certain points. It also helps us to determine if a function is differentiable, which is crucial for finding the derivative and solving related problems in calculus.
Can continuity be broken?
Yes, continuity can be broken if the function has a point where it is not defined or if the left and right limits at a certain point are not equal. In these cases, the function is said to have a discontinuity at that point, which means that it is not continuous.
How can I improve my understanding of continuity problems?
To improve your understanding of continuity problems, it is important to practice solving a variety of problems and to seek help from a teacher or tutor if you are struggling. You can also review the definitions and properties of continuity, and make sure to understand the concepts of limits and derivatives, which are closely related to continuity.
