MHB Solve cos 6x=(1/2) for principal values in degree
  • Thread starter Thread starter blake1
    Cos Degree
To solve the equation cos 6x = 1/2, the principal values of 6x are found at angles where cos equals 1/2, specifically at π/3 and 5π/3. This leads to multiple solutions for x within the range of 0 to 2π, including values such as π/18, 5π/18, and 17π/18. Converting these radian measures to degrees results in corresponding angles of 10°, 50°, and 170°. The complete set of solutions in degrees includes 10°, 50°, 70°, 110°, 130°, 170°, 190°, 230°, 250°, 290°, 310°, and 350°. The discussion emphasizes the importance of converting radian measures to degrees for clarity.
blake1
cos 6x=(1/2)
Mathematics news on Phys.org
blake said:
cos 6x=(1/2)
note $\cos{\theta} = \dfrac{1}{2}$ at $\theta = \dfrac{\pi}{3} \text{ and } \dfrac{5\pi}{3}$
$0 \le x < 2\pi \implies 0 \le 6x < 12\pi$
$\cos(6x) = \dfrac{1}{2} \implies 6x = \dfrac{\pi}{3} \, , \, \dfrac{5\pi}{3} \, , \, \dfrac{7\pi}{3} \, , \, \dfrac{11\pi}{3} \, , \, \dfrac{13\pi}{3} \, , \, \dfrac{17\pi}{3}\, , \, \dfrac{19\pi}{3} \, , \, \dfrac{23\pi}{3} \, , \, \dfrac{25\pi}{3} \, , \, \dfrac{29\pi}{3} \, , \, \dfrac{31\pi}{3} \, , \, \dfrac{35\pi}{3}$
$x = \dfrac{\pi}{18} \, , \, \dfrac{5\pi}{18} \, , \, \dfrac{7\pi}{18} \, , \, \dfrac{11\pi}{18} \, , \, \dfrac{13\pi}{18} \, , \, \dfrac{17\pi}{18}\, , \, \dfrac{19\pi}{18} \, , \, \dfrac{23\pi}{18} \, , \, \dfrac{25\pi}{18} \, , \, \dfrac{29\pi}{18} \, , \, \dfrac{31\pi}{18} \, , \, \dfrac{35\pi}{18}$
Skeeter's answer is, of course, in radians. To get the answer in degrees remember that \pi radians is 180 degrees. That is, \frac{180}{\pi}= 1 so \frac{\pi}{18} radians is the same as \frac{\pi}{18}\frac{180}{\pi}= 10 degrees.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
