MHB Solve Critical Thinking Math: Stopping Dist. 0.0074v²
  • Thread starter Thread starter JD003
    Thinking
The discussion revolves around solving a math homework problem involving the stopping distance of a car based on its speed, represented by the equation d = 0.0074v². Participants clarify that for the first two questions, one can simply plug in the speed values to find the stopping distance. For the third question, where the stopping distance is given, the task is to solve for speed, which can be done using the square root of the distance divided by the constant. There is an emphasis on maintaining academic integrity, as the assignment is graded, and the importance of understanding the underlying equations is highlighted. Ultimately, the discussion aims to help the original poster grasp the proper method for solving the problem while adhering to academic guidelines.
JD003
This is a homework assignment, I think I can work it out if I can set things up correctly. Do I to set up a quadratic equation in the form:
0 = ax + bx + c then factor for the zeros/solutions
(d) distance would be 0. But how do I put, (v) mph, with 0.0074v² ? More correctly asked I suppose is how do I separate it? If I simply plug v in, using #1. as the example, I see 0.0074(80)² and I know that's not getting me anywhere.
Thanks for any time you may have to help On a certain type of street surface, the equation d = 0.0074v² can be used to approximate the stopping distance d, in feet, a car traveling at a
speed of v miles per hour will need when its brakes are applied.
1. What is the cars stopping distance if its speed is 80 miles per hour?
The stopping distance would be ___ ft. (Round to nearest whole number.)
2. What is the cars stopping distance if its speed is 65 miles per hour?
3. A car was in an accident. When the traffic officer got to the scene, he noticed the length of the skid mark left by the car. The officer measured the stopping
distance and concluded that driver need 41 ft. to stop after applying the brakes. At what speed was the car going?
The speed of the car was ___ mph.
4. Did the officer issue the car owner a ticket for speeding if the speed limit was 65 mph.
O A. No
O B. Yes
Mathematics news on Phys.org
Is this problem part of a graded assignment, that is, does it contribute to your final grade?
The reason I ask is that our policy is not to provide help with graded work, as your professor most likely expects it to be your own work and we take academic honesty very seriously.
If this is a graded assignment, we can still help you with a similar problem from your textbook, so you can then gain an idea how to do the graded problem. :D
Ahh, yes it is graded. I'm not trying to circumvent the rules. I apologize that it does. I tried to phrase my question much like I would with one of the tutors at the library which is allowed at school at least. In that "I can figure it out of when I get the equation set up" I'm just not seeing how to do that.
We're not using a textbook. It's a hybrid class. 4 hrs a week classroom, the rest is on line in "Mylabs." When they do set up a "similar" example they just change the variables. In this case it would be the speed.
If I'm to far out of line, please feel free to delete the thread. And Again I apologize for bending or perhaps breaking the rules.Edit...Making progress. Turns out it's as easy as it looks in one respect.
In Questions 1 and 2 I'm just squaring (v), the speed and multiplying it by 0.0074. I'm getting correct answers
#1. 47 mph
#2. 31 mph
But I'm not impressed by my method. I still haven't drawn up the equation, I'm just calculating. Correct answers are enough for the grade but I'd like to set it up to solve for zero, which will serve me better down the road I'm sure.
I think the answer to #3 is 80 but again I don't see my method as proper.
It sounds to me like you are allowed to get outside help with our homework, if you are allowed to go to your school's tutors.
For the first two parts of the question, you are in fact only in need of plugging in for $v$ to find the value of $d$, since the equation you are given is solved for $d$.
For the third part, you are given $d$ and asked to find $v$, taking the positive root since $v$ is speed, which is non-negative. Can you solve the given equation for $v$?
One thing to note is that the two equations:
$d = kv^2$ and:
$kv^2 - d = 0$
are equivalent. You *CAN* use the quadratic formula on the 2nd equation, but it seems to me simpler to just find that:
$v = \pm \sqrt{\dfrac{d}{k}}$
(note that speed is usually taken to be the absolute value of velocity, which avoids the pesky question of signs).
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
