Solve DE for y: $\displaystyle y^\prime +y = xe^{-x}+1$
  • MHB
  • Thread starter karush
In summary, the given differential equation was solved by dividing every term by the integrating factor, simplifying and reordering terms to get the final answer of $y(x)=c_1e^{-x}+\frac{1}{2}e^{-x}x^2+1$. The steps taken include integrating, multiplying by the integrating factor, and simplifying the resulting expression.
karush
MHB
3,269
$\textsf{Given:}$
$$\displaystyle y^\prime +y = xe^{-x}+1$$
$\textit{Solve the given differential equation}$
$\textit{From:$\displaystyle\frac{dy}{dx}+Py=Q$}$
$\textit{then:}$
$$\displaystyle
e^x y=\int x+e^{-2x} \, dx
+ c \\
\displaystyle e^x y=\frac{1}{2}(x^2-e^{-2x})+c$$
$\textit{divide every term by $e^x$}$
$$\displaystyle y=\frac{1}{2(e^x)}(x^2)
-\frac{e^{-2x}}{2(e^x)}+\frac{c}{(e^x)}$$
$\textit{simplify and reorder terms}$
$$\displaystyle y=c_1e^{-x}+\frac{1}{2}e^{-x}x^2+1$$
$\textit{Answer by W|A}$
$$y(x)=\color{red}
{\displaystyle c_1e^{-x}+\frac{1}{2}e^{-x}x^2+1}$$
any bugs any suggest?
The integrating factor is:
\(\displaystyle \mu(x)=e^x\)
And so we get:
\(\displaystyle y'e^x+ye^x=x+e^x\)
\(\displaystyle \frac{d}{dx}\left(e^xy\right)=x+e^x\)
Integrate:
\(\displaystyle e^xy=\frac{x^2}{2}+e^x+c_1\)
Hence:
\(\displaystyle y(x)=\frac{x^2}{2}e^{-x}+1+c_1e^{-x}\)
Somehow you arrived at the correct answer, but your work doesn't show how.
MarkFL said:
Hence:
ok I hit and missed with some examples
but see your steps make a lot more sense
FAQ: Solve DE for y: $\displaystyle y^\prime +y = xe^{-x}+1$
What is a differential equation?
A differential equation is a mathematical equation that relates one or more functions and their derivatives. It is used to describe the relationship between a function and its rate of change.
How do you solve a differential equation?
To solve a differential equation, you must find a function that satisfies the equation. This involves using various techniques such as separation of variables, integration, and substitution.
What is the solution to the given differential equation?
The solution to the given differential equation is y = (x+2)e-x. This can be found by using the method of integrating factors.
Can you explain the steps taken to solve this particular differential equation?
To solve this differential equation, we first rearrange it to the form y' + Py = Q, where P and Q are functions of x. In this case, P=1 and Q=xe-x+1. Then, we find the integrating factor e∫Pdx, which in this case is ex. Multiplying both sides of the equation by this integrating factor, we get exy' + yex = x+2. This can then be solved by integrating both sides and applying the initial condition to find the value of the constant.
How are differential equations used in real life?
Differential equations are used in a variety of fields such as physics, engineering, economics, and biology to model and understand real-world phenomena. They are particularly useful in predicting how a system will change over time and are essential in the development of many technologies and processes.
