Solve Definite Integral: Invalid Answer Error
In summary, the conversation is about a person trying to solve a definite integral, but consistently getting an error. They have correctly set up the integral and simplified it, but are unsure of how to proceed with the final answer. They then mention using a calculator, but it gives them an error as well.
paulmdrdo1
385
i tried to solve this definite integral but i keep on getting an invalid answer. please check my error.
$\displaystyle \int_{-3}^{-2}\frac{y+2}{y^2+4y}dy$
$\displaystyle u=y^2+4y$
$\displaystyle du=2y+4dy$
$\displaystyle dy=\frac{du}{2y+4}$
$\displaystyle \frac{1}{2}\int\frac{y+2}{u}\times \frac{du}{2(y+2)}=\frac{1}{2}\int\frac{du}{u}= \frac{1}{2}\ln|u|+c= \frac{1}{2}\ln|y^2+4y|+c$
when i calculate the definite integral i always get an error.
$\displaystyle\frac{1}{2}\ln|(-2)^2+4(-2)|-\frac{1}{2}\ln|(-3)^2+4(-3)| = ?$
What you have done so far is correct...what is your final answer?
$\displaystyle\frac{1}{2}\ln|(-2)^2+4(-2)|-\frac{1}{2}\ln|(-3)^2+4(-3)| = \frac{1}{2}\ln|-4|-\frac{1}{2}\ln|-3|= ?$ i punch this in the calculator it gives me an error.
Use:
\(\displaystyle |-4|=4,\,|-3|=3\)
to write your solution.
FAQ: Solve Definite Integral: Invalid Answer Error
What does the "Invalid Answer Error" mean when solving a definite integral?
The "Invalid Answer Error" typically occurs when there is a mistake in the process of solving a definite integral. This can happen due to various reasons such as incorrect integration limits, incorrect use of integration techniques, or mathematical errors.
How can I fix the "Invalid Answer Error" when solving a definite integral?
To fix the "Invalid Answer Error", you should carefully check your integration steps and make sure that you have correctly applied the integration techniques. Double-check your integration limits and make sure they are in the correct order. If you still cannot find the error, try using a different integration technique or use a graphing calculator to verify your answer.
Can the "Invalid Answer Error" occur even if I have correctly solved the definite integral?
Yes, the "Invalid Answer Error" can occur even if you have correctly solved the definite integral. This can happen if your answer is in a form that the computer system is unable to recognize or if the answer is too large or too small for the system to handle. In these cases, you can try simplifying your answer or using scientific notation to represent it.
How can I avoid getting the "Invalid Answer Error" when solving a definite integral?
To avoid getting the "Invalid Answer Error", it is essential to be meticulous in your steps while solving the definite integral. Make sure to double-check your integration limits and use integration techniques correctly. It is also helpful to use a graphing calculator or online integral calculator to verify your answer.
Can the "Invalid Answer Error" indicate a problem with the definite integral itself?
Yes, in some cases, the "Invalid Answer Error" can indicate a problem with the definite integral itself. This can happen if the integral is improper or if it does not have a defined solution. In these cases, it is necessary to review the integral and make sure it is set up correctly. If the problem persists, it is best to seek assistance from a math tutor or professor.
