MHB Solve Derivative of Integral with F(x) - SnowPatrol Yahoo Answers
The discussion revolves around finding the derivative of the integral function F(x) defined as the integral of e^(t^2) from sin(x) to cos(x). The user initially struggles with the integration and differentiation process, leading to confusion about the application of the Fundamental Theorem of Calculus (FTOC). Ultimately, the correct derivative is derived using the FTOC and the Chain Rule, resulting in F'(x) = -sin(x)e^(cos^2(x)) - cos(x)e^(sin^2(x)). At x=0, this simplifies to F'(0) = -1. The thread concludes with a clarification on how to properly document the solution.
MarkFL
MHB
Here is the question:
Derivative of integral?
F(x) = integral of e^(t^2)dt (upper limit = cosx, lower limit = sinx)
Now find F'(x) at x=0
HOW DO I SOLVE THIS :O
Okay so this is what I did,
solve integration, answer is [e^(t^2)]/2t
[2t is the derivative of power(t^2), you're suppose to DIVIDE the integration by the derivative, riiight?]
I put t=cosx, t=sinx
So, it becomes
e^({cosx}^2)]/2cosx - e^({sinx}^2)]/2cosx
Now I take its derivative...
which turns out to be very complicated so I think I'm doing it wrong, because it is supposed to be not-so-long.
THIS IS THE ANSWER GIVEN AT THE BACK:
Answer:
F ′(x)=exp (cos2 (x)) ·−sin (x)−exp (sin2 (x)) · cos (x) by FTOC
F ′(0)=exp (1) · 0−exp (0) · 1=−1
NOW HOLD ON A SECOND.
ISNT DERIVATIVE OF AN INTEGRAL, THE FUNCTION ITSELF? YESSSS.
OKAY, BUT THE DERIVATIVE AND INTEGRAL DONT UMMM CANCEL OUT TILL THE dx/dy/dt IS SAME WITH DERIVATIVE AND INTEGRATION!
Okay, I somehow solved the question B) *pat pat*
Can someone tell me how do i write this down on my paper?? O.o
I have posted a link there to this thread so the OP can view my work.
Mathematics news on Phys.org
Hello SnowPatrol,
We are given:
$$F(x)=\int_{\sin(x)}^{\cos(x)} e^{t^2}\,dt$$
And we are asked to find $F'(0)$.
By the FTOC and the Chain Rule, we have:
$$\frac{d}{dx}\int_{g(x)}^{h(x)} f(t)\,dt=f(h(x))\frac{dh}{dx}-f(g(x))\frac{dg}{dx}$$
Applying this formula, we find
$$F'(x)=-\sin(x)e^{\cos^2(x)}-\cos(x)e^{\sin^2(x)}$$
Hence:
$$F'(0)=-\sin(0)e^{\cos^2(0)}-\cos(0)e^{\sin^2(0)}=0-1=-1$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
