Solve Diff Eq: Change of Coordinates to Eliminate Squared Terms
In summary, substituting into the differential equation results in an equation for that is a change of coordinates. If both series are convergent within some area around zero, they will be the same.
Fantini
MHB
268
Here is the question:
Consider the differential equation
with . Show that there exists a change of coordinates of the form that rewrites the equation (locally around ) as
that is, that eliminates the squared term.
I have no idea how to go about it.
Substitute into the differential equation?
First of all, for convenience, I will write
Now, if you try substituting in, you get
First of all, note that . As for the other side, we can note that
I'm not sure where to go from there either, but I think it might help to have it down. I suppose it might have something to do with finding a condition on so that divides
Following TheBigBadBen's approach, . Now use the binomial expansion of (assuming that it converges) to get You can now put the coefficient of equal to to get an equation for . But that is a rather heuristic, non-rigorous method. I'm not sure how to deal with the requirement that this should be a change of coordinates.
This is what I thought as well, but he said we would use something like the inverse function theorem or the implicit function theorem. How would we apply any of these there?
I believe that is a change of coordinates.
Furthermore, if both series are convergent within some area around zero, they will be the same.
I don't see how you might use either of those theorems in a useful manner.
I believe this settles the question. I don't think there's much more to be done than what we did so far. Thanks! :)
FAQ: Solve Diff Eq: Change of Coordinates to Eliminate Squared Terms
What is a differential equation?
A differential equation is a mathematical equation that describes the relationship between a function and its derivatives. It is used to model many physical phenomena in fields such as physics, engineering, and economics.
How does a change of coordinates help solve a differential equation?
A change of coordinates involves transforming a given set of variables in a differential equation into a new set of variables. This can help simplify the equation and make it easier to solve by eliminating squared terms or other complex expressions.
When should a change of coordinates be used to solve a differential equation?
A change of coordinates is most commonly used when solving linear or nonlinear differential equations with constant coefficients. It can also be used to solve higher-order differential equations or equations with non-constant coefficients.
What are the steps involved in using a change of coordinates to eliminate squared terms?
The first step is to identify the squared terms in the differential equation. Then, a substitution is made by setting the squared term equal to a new variable. This new variable can then be eliminated by using another equation or by substituting back into the original equation. Finally, the solution is obtained by solving the resulting differential equation with the substituted variable.
Are there any limitations to using a change of coordinates to solve a differential equation?
A change of coordinates can be a powerful tool in solving differential equations, but it may not always be possible to find a suitable transformation. In some cases, the transformed equation may be more complex than the original equation. Additionally, a change of coordinates may not work for certain types of differential equations, such as those with non-constant coefficients.
