Solve differential equation if you now two solutions
In summary, the general solution to the given differential equation is ##y= e^x-A(x^2+1)##, where A is an arbitrary constant, and the solution is obtained by adding a particular solution of the inhomogeneous equation to the general solution of the homogeneous equation. The homogeneous part of the equation can be found by substituting the correct values for b(x) and c(x) and solving, or by substituting the trial solution into the homogeneous equation and checking for a solution.
skrat
748
Let ##y_1(x)= e^x## and ##y_2=x^2+1+e^x## solve the differential equation ##y^{'}+b(x)y=c(x)##.
Find the overall solution of this differential equation.
The overall solution => ##y=y_H+y_P## I don't know the english expression for that but in general the idea behind is that differential equations can be seen as homogeneous and inhomogeneous.
If ##y_1(x)= e^x## and ##y_2=x^2+1+e^x## solve the equation than their ##y_1-y_2## also solves the equation. But I am not sure which part? Homogeneous or inhomogeneous?
I would like to say that the right answer is homogeneous part but than the overall solution would be like ##y= e^x-A(x^2+1)##
Does this sound right? :/
Yes, the function ##y_{1}-y_{2}## is a solution to the homogenous equation. You get the general solution of the homogenous case by noting that also ##C(y_{1}-y_{2})##, where ##C## is any constant, is a solution. Now you only add a particular solution of the inhomogenous case to this solution, and you have the general solution of the full inhomogenous equation.
b(x) and c(x) are not given, but they are obtained knowing two solutions of the equation.
Once you know b(x) and c(x), you can find the general solution of the homogeneous equation, yh. Adding any particular solution (which can be any linear combination of y1 and y2, independent from yh), you get the general solution.
ehild
ehild
Well this complicates this problem A LOT:
If ##y_1(x)= e^x## and ##y_2(x)=x^2+1+e^x## solve the differential equation ##y^{'}+b(x)y=c(x)##
Than ##y_1^{'}(x)= e^x## and ##y_2^{'}(x)=2x+e^x## and
##e^x+b(x)e^x=c(x)## and ##2x+e^x+b(x)(x^2+1+e^x)=c(x)##. Multiplying the first equation with -1 and them summing both of them together gives:
##2x+b(x)2x+b(x)x^2=0##
##b(x)=\frac{-2}{2+x}## and accordingly ##c(x)=e^x\frac{x}{2+x}##
Original equation is than written as:
##y^{'}+b(x)y=y^{'}+\frac{-2}{2+x}y=e^x\frac{x}{2+x}##
Now I have to find homogeneous and non homogeneous part in order to find the general solution? That's sounds like a lot of work.
So, the only reason than ##y_1## and ##y_2## are given is so I can find b(x) and c(x)?
You made some mistake, it should be ##b(x)=\frac{-2x}{x^2+1}##
The overall (general ) solution => ##y=y_H+y_P## I don't know the english expression for that but in general the idea behind is that differential equations can be seen as homogeneous and inhomogeneous.
The homogeneous part of the equation is y'+b(x)y=0. Substitute the correct b(x) and c(x) and solve. Or substitute your trial solution into the homogeneous equation and see if it is a solution.
You get the general solution of the equation if you add a particular solution of the inhomogeneous equation to the general solution of the homogeneous equation. Yes, the general solution is ##y= e^x-A(x^2+1)## where A is an arbitrary constant.
ehild
FAQ: Solve differential equation if you now two solutions
How do you solve a differential equation if you know two solutions?
To solve a differential equation, you can use the method of undetermined coefficients or the method of variation of parameters. In both of these methods, you can use the two known solutions to determine the coefficients and parameters needed to solve the equation.
Can you use any two solutions to solve a differential equation?
No, the two solutions must be linearly independent in order to solve the differential equation. This means that they cannot be multiples of each other.
What if I only have one known solution?
If you only have one known solution, you can use that solution to find a second linearly independent solution. This can be done using the method of reduction of order.
Are there other methods for solving differential equations with known solutions?
Yes, there are other methods such as the method of separation of variables, the method of Laplace transforms, and the method of power series. However, these methods may not require knowledge of two solutions to solve the differential equation.
Is it necessary to know the solutions to solve a differential equation?
No, it is not always necessary to know the solutions to solve a differential equation. Some methods, such as the method of separation of variables, do not require knowledge of solutions to solve the equation. However, having knowledge of solutions can make the solving process easier and more accurate.
