MHB Solve Differential Equation w/ Power Series Method
evinda
MHB
Hello! (Wave)
The differential equation $y''+xy=0$ is given.
Find the general solution of the differential equation (with the power series method).
That's what I have tried:
We are looking for a solution of the form $y(x)=\sum_{n=0}^{\infty} a_n x^n$, where the radius of convergence is $R>0$.
$xy(x)=\sum_{n=1}^{\infty} a_{n-1}x^n$.
We have $y'(x)= \sum_{n=0}^{\infty} (n+1)a_{n+1} x^n$.
$y''(x)=\sum_{n=0}^{\infty} (n+2)(n+1) a_{n+2} x^n$.
So it has to hold:
$$2a_2 + \sum_{n=1}^{\infty} \left[ (n+2)(n+1) a_{n+2}+a_{n-1}\right]x^n=0, \forall x \in (-R,R)$$
Thus:
$$a_2=0$$
$$(n+2)(n+1)a_{n+2}+a_{n-1}=0, \forall n=1,2,3, \dots$$
$$3 \cdot 2 \cdot a_3+a_2=0 \Rightarrow a_3=0$$
$$4 \cdot 3 \cdot a_4 +a_1=0 \Rightarrow a_4=-\frac{a_1}{12}$$
Is it right so far? Or have I done something wrong?
evinda said:
Hello! (Wave)
So it has to hold:
Thus:
$$a_2=0$$
The solution of the ODE...
$\displaystyle y^{\ ''} + x\ y = 0\ (1)$
... requires the knowledege of $y(0)$ and $y^{\ '} (0)$...
... suppose to have a solution of the form $\displaystyle y(x)= \sum_{n=0}^{\infty} a_{n}\ x^{n}$ You have...
$\displaystyle y^{\ '} (x) = \sum_{n=0}^{\infty} n\ a_{n}\ x^{n-1}\ (2)$
$\displaystyle y^{\ ''} (x) = \sum_{n=0}^{\infty} n\ (n-1)\ a_{n}\ x^{n-2}\ (3)$
... so that is...
$\displaystyle y^{\ ''} (x) = \sum_{n=0}^{\infty} n\ (n-1)\ a_{n}\ x^{n-2} = - \sum_{n=0}^{\infty} a_{n}\ x^{n+1}\ (4)$
Here $a_{0}$ and $a_{1}$ are given from the initial conditions, and the successive coefficients can be found with (4) ...
$\displaystyle y^{\ ''} = 2\ a_{2} + 6\ a_{3}\ x + 12\ a_{4}\ x^{2} + ... = - a_{0}\ x - a_{1}\ x^{2} - ... \implies a_{2} = 0$
$\displaystyle y^{\ '''} = 6\ a_{3} + 24\ a_{4}\ x + ... = - a_{0} - 2\ a_{1}\ x - ... \implies a_{3} = - \frac{a_{0}}{6}$...
... and so one...
Kind regards
$\chi$ $\sigma$
I found that $y''(x)= \sum_{n=1}^{\infty} (n+1) a_{n+1} n x^{n-1}= \sum_{n=0}^{\infty} (n+2) (n+1) a_{n+2} x^n$.
Am I wrong? (Thinking)
Is...
$\displaystyle y(x) = \sum_{n = 0}^{\infty} a_{n}\ x^{n}\ (1)$
... and if the series (1) uniformely converges in an interval You can derive it 'term by term' obtaining...
The same is for the series (2) so that is...
$\displaystyle y^{ ''} (x) = \sum_{n=0}^{\infty} n\ (n-1)\ a_{n}\ x^{n - 2}\ (3)$
Kind regards
$\chi$ $\sigma$
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
