Solve Equation: $a^3+3a^2-51a-107+54\sqrt{3}=0$
  • MHB
  • Thread starter anemone
In summary: Keep 'em coming!(Hug)I certainly will!(Star)Thanks, DreamWeaver! And...welcome back to MHB!(Sun)(Coffee)
anemone
MHB
POTW Director
3,883
115
Solve for the equation $a^3+3a^2-51a-107+54\sqrt{3}=0$
Mathematics news on Phys.org
using Descartes' rule of signs ,and intermediate value theorem we know this equation must have 1 positive root
and two negative roots
f(5)f(6)<0 (5<a positive root<6 )
f(0)f(-1)<0 (-1<a negative root<0)
f(-8)(-9)<0(-9<another negative root<-8)
we can use Newton's method to find more accurate roots of the equation
This took me ages to work out. Once I had solved the equation (by a very indirect method), I could see a much quicker way to verify the answer.
[sp]Start with the fact (see here) that $\cos105^\circ = -\frac{\sqrt3-1}{2\sqrt2}$. Using the fact that $\cos(3\theta) = 4c^3 - 3c$, where $c = \cos\theta$, it follows that the solutions of the equation $4c^3 - 3c = -\frac{\sqrt3-1}{2\sqrt2}$ are $c = \cos35^\circ$, $c = \cos155^\circ$ and $c = \cos275^\circ$.
Now let $x = 6\sqrt2c$. The equation $4c^3 - 3c = -\frac{\sqrt3-1}{2\sqrt2}$ becomes $$ 4\Bigl(\frac x{6\sqrt2}\Bigr)^3 - 3\Bigl(\frac x{6\sqrt2}\Bigr) = -\frac{\sqrt3-1}{2\sqrt2}.$$ Multiply through by $54$ to get $x^3 - 54x = -54(\sqrt3-1).$
Next, let $a = x-1$. The equation becomes $(a+1)^3 - 54(a+1) = -54(\sqrt3-1),$ or $a^3 +3a^2 + 3a + 1 - 54a - 54 + 54\sqrt3 - 54 = 0.$ That simplifies to the given equation $a^3+3a^2-51a-107+54\sqrt{3}=0$. Since $a = x-1 = 6\sqrt2c-1$, the solutions of the equation are $$ a = 6\sqrt2\cos35^\circ - 1, \quad 6\sqrt2\cos155^\circ - 1, \quad 6\sqrt2\cos275^\circ - 1.$$
[You can check that these lie in the numerical intervals given by Albert.][/sp]
This is just awesome! (Clapping) (Bow)
Thanks, Albert for your suggestion of the use of numerical method to tackle this problem.:)
Hey Opalg, I really like the way how you verified the answer, well done Opalg and thanks for participating to both of you!
Solution suggested by other:
First, we manipulate the original equation $a^3+3a^2-51a-107+54\sqrt{3}=0$ by rewriting it as below:
$a^3+3a^2+(3a+1)-(3a+1)-51a-107+54\sqrt{3}=0$
$(a^3+3a^2+3a+1)-54a-108+54\sqrt{3}=0$
$(a+1)^3-54a-54-54+54\sqrt{3}=0$
$(a+1)^3-54(a+1)-54(1-\sqrt{3})=0$
$b^3-54b-54(1-\sqrt{3})=0$(*) if $b=a+1$
If we want to further solve the equation, we have to resort to use the triple angle formula for cosine function since $\cos 3x=4\cos^3x-3\cos x$, i.e., we must make $b^3-54b$ to take the form of $4\cos^3x-3\cos x$ and this could be done by observing that:
$\dfrac{b^3}{54b}=\dfrac{4\cos^3 x}{3\cos x}$ and this gives $b=\sqrt{72} \cos x$ and substituting it back to (*) we get:
$(\sqrt{72} \cos x)^3-54(\sqrt{72} \cos x)-54(1-\sqrt{3})=0$
$72\sqrt{72} \cos^3 x-54\sqrt{72} \cos x-54(1-\sqrt{3})=0$
$18\sqrt{72}(4 \cos^3 x-3\cos x)-54(1-\sqrt{3})=0$
$18\sqrt{72}\cos 3x-54(1-\sqrt{3})=0$
$\begin{align*}\cos 3x&=\dfrac{54(1-\sqrt{3})}{18\sqrt{72}}\\&=\dfrac{-(\sqrt{3}-1)}{2\sqrt{2}}\end{align*}$
Remember that
$\begin{align*}\cos 75^{\circ}&=\sqrt{\dfrac{\cos 150^{\circ}+1}{2}}\\&=\sqrt{\dfrac{-\dfrac{\sqrt{3}}{2}+1}{2}}\\&=\dfrac{\sqrt{4-2\sqrt{3}}}{2\sqrt{2}}\\&=\dfrac{\sqrt{3-2\sqrt{3}+1}}{2\sqrt{2}}\\&=\dfrac{\sqrt{(\sqrt{3}-1)^2}}{2\sqrt{2}}\\&=\dfrac{\sqrt{3}-1}{2\sqrt{2}} \end{align*}$
So, $\cos (180^{\circ}-75^{\circ})=\cos 105^{\circ}=\dfrac{-(\sqrt{3}-1)}{2\sqrt{2}}$ and the other two smallest positive values for $3x$ are $360^{\circ}-105^{\circ}=255^{\circ}$ and $360^{\circ}+105^{\circ}=465^{\circ}$ and this gives $x=35^{\circ},\,85^{\circ},\,155^{\circ},\,$ or $a=\sqrt{72}\cos 35^{\circ}-1,\,\sqrt{72}\cos 85^{\circ}-1,\,\sqrt{72}\cos 155^{\circ}-1$.
Great thread, Anemone. As per usual... ;)(Ninja)(Sun)
Thank you...! (Sun) It's great to be back!
Thoroughly glad to hear it. Personally, I think you add so much great material on here that we ought to rename it the "Anemone Board" (sorry, everyone else, but you know it makes sense ;) )
I'm enormously flattered that you like my challenge posts...but, there are also those who took part in my challenges that ought to gain some sort of recognition as well!:p Also, this site main function is for the students from the four corners of the world to asking for help when they encountered difficulty in solving any of the mathematics problems, my posts are really only serve to complement MHB...:D But I truly know you mean well...(Star) Thanks, buddy!(Sun)
Overall, MHB is a very good name and actually the third letter $B$ means very much to me because that is also the first letter of my nick name!(Sun)
anemone's challenge problems are certainly a staple of MHB. We are very pleased that she works so hard to do this for MHB. (Clapping)(Sun)
FAQ: Solve Equation: $a^3+3a^2-51a-107+54\sqrt{3}=0$
What is the process for solving this equation?
The first step in solving this equation is to isolate the radical term by subtracting 54√3 from both sides. This will leave you with a cubic equation of the form a^3+3a^2-51a-161=0. Then, using the Rational Root Theorem, you can determine possible rational roots and test them using synthetic division. Once you have found a rational root, you can factor the equation and use the quadratic formula to solve for the remaining roots.
Can this equation be solved without using the Rational Root Theorem?
Yes, it is possible to solve this equation using other methods such as factoring, completing the square, or using the cubic formula. However, the Rational Root Theorem is often the most efficient method for finding rational roots in a cubic equation.
Is there a unique solution for this equation?
Yes, this equation has a unique solution. Cubic equations can have up to three distinct solutions, but this particular equation only has one solution.
Can technology be used to solve this equation?
Yes, technology such as graphing calculators or computer programs can be used to solve this equation. They can help with finding rational roots, factoring, and solving for the remaining roots using the quadratic formula.
Are there any real solutions for this equation?
Yes, this equation has at least one real solution. This can be determined by graphing the equation and seeing where it intersects the x-axis.
