MHB Solve Equation: Find Real $a$ for $10^a+12^a-14^a=13^a-11^a$
  • Thread starter Thread starter anemone
The equation 10^a + 12^a - 14^a = 13^a - 11^a is analyzed through the function f(x) = 10^x + 11^x + 12^x - 13^x - 14^x. It is determined that f(x) equals zero at x = 2. For values greater than 2, the function decreases sharply due to the dominance of negative terms, while for values less than 2, positive terms dominate, keeping f(x) positive. Thus, x = 2 is identified as the only solution to the equation. The analysis concludes that the only real number a satisfying the equation is a = 2.
anemone
MHB
POTW Director
Find all real numbers $a$ for which $10^a+12^a-14^a=13^a-11^a$.
Mathematics news on Phys.org
a= 2
is a aolution
Take $f(a) = 14^a + 13^a – 12^a – 11 ^a – 10 ^a
= (14^a – 12^a) + (13^a – 11^a ) – 10^a$
We have $14^3 – 12^3 > 10^3$ and gap increases for a >=3 the expression is positive
So we need to look for value < 3
Check for 0 , 1, 2 and we see that a =2 is the integer solution
It may have some non integer solution
[sp]Let's consider the function...
$\displaystyle f(x) = 10^{x} + 11^{x} + 12^{x} - 13^{x} - 14^{x}\ (1)$
By inspection we find easily that (1) vanishes for x=2. For x>2 the negative terms of (1) are dominating, so that thye function sharply decreases. For x<2 the positive terms of (1) are dominating so that is $\lim_{x \rightarrow - \infty} f(x) = 0$ and everywhere is f(x) > 0. The conclusion is that x=2 is the only zero of f(x)...[/sp]
Kind regards
$\chi$ $\sigma$
Solution:
Given $10^a+11^a+12^a = 13^a+14^a$
Now Divide both side by $(12.5)^a$, where $(11.5)^a>0\forall a\in \mathbb{R}$
So $\displaystyle \left(\frac{10}{12.5}\right)^a+\left(\frac{11}{12.5}\right)^a+\left(\frac{12}{12.5}\right)^a = \left(\frac{13}{12.5}\right)^a+\left(\frac{14}{12.5}\right)^a$
So Here $\bf{L.H.S}$ is a sum of strictly Decreasing function while $\bf{R.H.S}$ is a sum of strictly increasing function.
So these two exponential curves intersect each other exactly at one point
So by inspection we get $a = 2$ only solution.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
  • · Replies 19 ·
  • · Replies 68 ·
12K
  • · Replies 24 ·
