Solve Equation: \frac{x}{2}+3=\frac{x+2}{3}-x
  • MHB
  • Thread starter headbang
In summary, we simplified the equation by finding the least common multiple of the denominators (6), multiplying both sides by it, and then solving for x to get the solution of x = -2.
headbang
Ok have other solve Equations..
\(\displaystyle \frac{x}{2}+3=\frac{x+2}{3}-x\)
Mathematics news on Phys.org
We should get rid of those denominators...what is the smallest number we can multiply both sides by so that the denominators will be gone?
Ok hav to be 6.. 2*3
\(\displaystyle \frac{2*3*x}{2}+6*3=\frac{x*2*2*3}{3}-x*6\)
\(\displaystyle 3x+18=4x-6x\)
\(\displaystyle 3x-4x-6x+18=\)
\(\displaystyle -7x=-18\)
\(\displaystyle 7x=18\)
OK ?
OK ?
There's a problem in line 1. The RHS shold be
\(\displaystyle \frac{(x + 2) \cdot 2 \cdot 3}{3} - 6x\)
Not quite...you did pick the correct value, the LCM of 2 and 3...but you multiplication wasn't quite right...
\(\displaystyle 6\left(\frac{x}{2}+3\right)=6\left(\frac{x+2}{3}-x\right)\)
\(\displaystyle 3x+18=2(x+2)-6x\)
\(\displaystyle 3x+18=2x+4-6x\)
Try it from there...
My attitude is always SIMPLIFY before trying to do anything.
Each side is the sum of a fractional amount (even whole numbers are fractions with 1 as the denominator). How do you add fractions?
Then I would make use of the fact that if two fractions that have the same denominator are equal, then the numerators must be equal to (as the denominator tells you the TYPE of parts you have, if both sides have the same type of parts, then the only way that the fractions can be equal is if they have the same NUMBER of these type of parts, in other words, if the numerators are equal).
\(\displaystyle 3x-2x+6x=4-18\)
\(\displaystyle \frac{7x}{7}=\frac{-14}{7}\)
\(\displaystyle x=-2\)An other try... Is it ok?
And thank you all so much for helping me, trying to get my head around this math.. You are all worth your weight in gold...
Your algebra looks good, but let's check your answer in the original equation:
\(\displaystyle \frac{-2}{2}+3=\frac{-2+2}{3}-(-2)\)
\(\displaystyle -1+3=0+2\)
\(\displaystyle 2=2\)
Yes, your solution works! (Yes)
FAQ: Solve Equation: \frac{x}{2}+3=\frac{x+2}{3}-x
What is the first step to solving this equation?
The first step to solving this equation is to combine like terms on each side of the equation. This means combining the x terms and the constant terms separately.
How can I eliminate fractions in this equation?
To eliminate fractions, you can multiply both sides of the equation by the lowest common denominator. In this case, the lowest common denominator is 6.
Can I solve this equation by simply adding or subtracting the terms?
No, you cannot solve this equation by simply adding or subtracting the terms. You must follow the proper steps of isolating the variable on one side of the equation.
What is the final solution for this equation?
The final solution for this equation is x = -6.
Are there any restrictions or special cases for this equation?
Yes, there is a restriction for this equation. The value of x = -6 is the only solution that satisfies the equation. Any other value for x will make the equation false.
