Solve equation: $y+k^3=\sqrt[3]{k-y}$
  • MHB
  • Thread starter anemone
In summary, the participants discuss an equation and its inverse function, which involves a real parameter k. Jacks provides a solution that is praised for its simplicity and elegance. Anemone asks a question about the implication of the equation and its solution. In response, jacks explains that the function identity leads to the implication being true.
anemone
MHB
POTW Director
3,883
115
Solve the equation $y+k^3=\sqrt[3]{k-y}$ where $k$ is a real parameter.
Mathematics news on Phys.org
Consider function $f(k) = y + k^3$, then $f^{-1}(k) = \sqrt[3]{k - y}$. Hence \[f^{-1}(k) = f(k)\] This can happen if and only if \[k = f(k) = f^{-1}(k)\] i.e. \[k = \sqrt[3]{k - y} = y + k^3\] So \[\boxed{y = k - k^3}\]
Hey jacks, thanks for participating and your solution is simple, elegant and nice! Well done, jacks!:)
Hi, anemone and jacks!
Thankyou for your answers. Jacks solution is very elegant!(Star)
I have one question. I do not understand why the following implication is true:
$$ f(k)=y+k^3 \Rightarrow f^{-1}(k)=\sqrt[3]{\mathbf{k}-y} $$
Why is k appearing on the RHS?
I would deduce the following:
$$ f(k)=y+k^3 \Rightarrow f^{-1}(k)=\sqrt[3]{f(k)-y}$$
By definition:
$$f(k)=y+k^3=\sqrt[3]{k-y}=\sqrt[3]{f(k)-y} \Rightarrow f(k) = k \Rightarrow y+k^3=k \Rightarrow y = k-k^3$$
By definition:
Hi lfdahl,
I am sorry for I only replied to you days after...I thought to myself to let jacks to handle it and I would only chime in if we didn't hear from jacks 24 hours later. But it somehow just slipped my mind.:(
Back to what you asked us...I believe if we use the identity
$f(f^{-1}(k))=k$,
and that for we have $f(k)=y+k^3$, we would end up with getting $f^{-1}(k)=\sqrt[3]{\mathbf{k}-y} $, does that answer your question, lfdahl?:)
$f(k)=y+k^3$
$f(f^{-1}(k))=k$
$y+(f^{-1}(k))^3=k$
$(f^{-1}(k))^3=k-y$
$f^{-1}(k)=\sqrt[3]{k-y}$
FAQ: Solve equation: $y+k^3=\sqrt[3]{k-y}$
What is an equation?
An equation is a mathematical statement that shows the relationship between two or more quantities. It typically consists of variables, constants, and mathematical operations, and it can be solved to find the value of the unknown variable(s).
What does it mean to solve an equation?
Solving an equation means finding the value(s) of the variable(s) that make the equation true. This is usually done by performing a series of mathematical operations on both sides of the equation until the variable is isolated and its value can be determined.
What is the process for solving this specific equation?
To solve the equation $y+k^3=\sqrt[3]{k-y}$, you first need to isolate the variable(s) on one side of the equation. This can be done by subtracting $k^3$ from both sides. Then, cube both sides to eliminate the cube root on the right side. Finally, you can solve for y by subtracting y from both sides and factoring to get y by itself.
Are there any restrictions on the values of k and y for this equation?
Yes, there are restrictions on the values of k and y for this equation. The cube root function requires that the radicand (the value inside the cube root) be non-negative, so k-y must be greater than or equal to 0. Additionally, the cube root of 0 is 0, so k-y cannot be equal to 0.
Can this equation have more than one solution?
Yes, this equation can have more than one solution. Since there is a cube root on one side of the equation, there will be three possible solutions for y. However, when solving for y, you may need to consider any restrictions on the values of k and y to determine which solutions are valid.
