Solve f(t) with Heaviside Functions: Find b
In summary, the function f(t) can be expressed as 7H(t) + bH(t-5), where b is equal to -34/7. However, it should be noted that the function as written cannot be expressed as a combination of Heaviside steps and the link provided should be removed from the post. To accurately represent the function, it should be written as f(x)=7H(x)+8H(x-5) and checked at the steps to ensure correctness.
Uniman
Consider the function
Then f(t) can be expressed with Heaviside functions as
Determine b.
Workdone so far...
f(t) = 7H(t) + bH(t-5)
when t = 5
f(5) = 49 + 7b
15 = 49 + 7b
-34 = 7b
b = -34/7
http://www.chegg.com/homework-help/questions-and-answers/-q3136934#
Is the answer correct...​
Mathematics news on Phys.org
Determine b.
Workdone so far...
when t = 5
f(5) = 49 + 7b
15 = 49 + 7b
-34 = 7b
b = -34/7
As it is written your function cannot be written as a combination of Heaviside steps, since such a combination is defined on the whole real line, but the domain of your function is just the positive real line. So you either to use Heaviside steps restricted to the \(x>0\) of you need to specify that your function is zero foir \(x<0\).
Anyway what you probably want is \(f(x)=7H(x)+8H(x-5)\) and then to check that this is correct at the steps (this is \(0\) up to \(0\), \(7\) from \(0\) to \(5\) and \(7+8=15\) past \(x=5\) )
Also remove the link from your post.
CB
FAQ: Solve f(t) with Heaviside Functions: Find b
What is the purpose of using Heaviside functions to solve for f(t)?
The Heaviside function, also known as the unit step function, is often used in mathematical models to represent a sudden change or discontinuity in a system. It allows us to simplify complex functions and make them easier to analyze and solve.
How do you solve for b in a function using Heaviside functions?
To solve for b, we can use the properties of the Heaviside function. We can set up equations using the step function to represent the different sections of the function and then use algebra to isolate and solve for b.
Can Heaviside functions be used in real-world applications?
Yes, Heaviside functions are commonly used in engineering, physics, and other scientific fields to model real-world systems. They can be used to analyze and predict the behavior of systems with sudden changes or discontinuities.
What are some other common applications of Heaviside functions?
Aside from solving functions, Heaviside functions are also used in signal processing, control systems, and circuit analysis. They are also used in probability and statistics to represent step-wise probability distributions.
Are there any limitations to using Heaviside functions in solving for b?
While Heaviside functions are useful in simplifying functions and solving for b, they may not be suitable for complex systems with multiple discontinuities. In these cases, other mathematical tools may be needed for accurate analysis and solutions.
