Solve Factoring Problem: (x+y)^2+2(X+Y)+1
  • MHB
  • Thread starter caligari
  • Tags
    Factoring
In summary, the given expression (x+y)^2+2(x+y)+1 can be simplified to (x+y+1)^2 by using the substitution u=x+y. This is because (x+y)^2+2(x+y)+1 is equivalent to u^2+2u+1, which is the square of (u+1). Therefore, the final answer is (x+y+1)^2.
caligari
The problem is
(x+y)^2+2(X+Y)+1
and the answer is supposed to be (X+1+Y)^2
I looked it up on this calculator but the second step makes no sense. First I do not know how the +2 disappears and where the extra (X+Y) come from. Also it's explanation when you click on the black box doesn't make sense. It says "For a quadratic equation of the form ax2+bx+c find u,v such that: u(v)=a(c) and u+v=c.
What are u and c and also in the next step it shows it as this
((x+y)+1))((x+y)^2+(x+y)) If the hint tells me to put it in ax2+bx+c then why are there only two terms in this. THis step makes no sense.
Here is the link to the calculator and problem
https://www.symbolab.com/solver/abs...right)^{2}+2\left(x+y\right)+1/?origin=button
Mathematics news on Phys.org
Hello and welcome to MHB, caligari! :D
We are given to factor:
\(\displaystyle (x+y)^2+2(x+y)+1\)
Now, suppose we let $u=x+y$, and then we have:
\(\displaystyle u^2+2u+1\)
You should recognize this as the square of $u+1$, hence:
\(\displaystyle u^2+2u+1=(u+1)^2\)
And so, back-substituting for $u$, we obtain:
\(\displaystyle (x+y)^2+2(x+y)+1=(x+y+1)^2\)
caligari said:
The problem is
(x+y)^2+2(X+Y)+1
Just a quick note:
Mathematics is "case sensitive." X and x are not the same variable.
-Dan
FAQ: Solve Factoring Problem: (x+y)^2+2(X+Y)+1
What is factoring?
Factoring is a mathematical process of finding two or more numbers or variables that, when multiplied together, will produce a given number or algebraic expression.
How do you solve a factoring problem?
To solve a factoring problem, you need to factor out the common terms in the given expression. This can be done by finding the greatest common factor (GCF) of the terms and then using the distributive property to rewrite the expression as the product of the GCF and the remaining terms.
What is the difference between factoring and expanding?
Factoring and expanding are essentially inverse operations. Factoring involves breaking down a polynomial into its factors, while expanding involves multiplying out the factors to get back to the original polynomial. In other words, factoring "undoes" the process of expanding.
Can you use the quadratic formula to solve this factoring problem?
No, the quadratic formula is used to solve quadratic equations, which have a specific format of ax^2 + bx + c = 0. The expression (x+y)^2+2(X+Y)+1 is not a quadratic equation, so the quadratic formula cannot be used to solve it.
What is the importance of factoring in mathematics?
Factoring is an important skill in mathematics because it allows us to simplify and solve complex algebraic expressions and equations. It is also used in many other areas of mathematics such as calculus, number theory, and cryptography.
