Solve Factorization of ##a^6-b^6## - Different Approach
  • Thread starter chwala
In summary, the equation ##a^6-b^6## can be factored into ##(a-a_k)## where ##a_k## is a root of the equation.
chwala
390
factorize ##a^6-b^6##
factorization
##a^6-b^6##≡##(a^3-b^3)(a^3+b^3)##
≡##(a-b)(a^2+ab+b^2)(a+b)(a^2-ab+b^2)##
and
##(a^2-ab+b^2)(a^2+ab+b^2)≡(a^4+2a^2b^2+b^4)##
letting ##a^2=x, b^2=y##
##a^4+2a^2b^2+b^4= x^2+2xy+y^2)##
=##(x+y)(x+y)##
thus,
##a^6-b^6##=##(a-b)(a+b)(a^2+b^2)(a^2+b^2)##
is there a different approach to this?
You might want to plug in some values for a and b to check.
chwala said:
Homework Statement:: factorize ##a^6-b^6##
Relevant Equations:: factorization
I would stop right there. It's factored.
Likes chwala
Thanks, yeah right...i know i am right i thought the math wizards here might have a different approach to it...Thanks LCkurtz. :wink:
@LCKurtz is correct. Stop here -- it's factored.
chwala said:
and
No, the middle term on the right side is incorrect. You should have gotten ##a^4 + a^2b^2 + b^4##
=##(x+y)(x+y)##
thus,
Likes chwala
yes, my expansion is wrong. I did this in a hurry oops... :wink:
Klystron said:
Perhaps you are thinking of the binomial theorem?
interesting, i do not see how one can use binomal expansion on this, kindly show me how...i had thought of that initially...
Likes HallsofIvy
i am still waiting for your approach ...
Unless I'm missing something, I don't see how the binomial theorem is applicable here. It deals with a sum or difference of variables raised to some power, not the sum or difference of powers. IOW, the domain of application for the binomial theorem is expressions such as ##(a \pm b)^n##.
As already noted, your first factorization in post #1 is correct, and the second one is incorrect. Once you have found the prime factors of a number or an algebraic expression, that factorization is unique, so why should there necessarily be another approach?
Likes chwala
Since you had already factored the equation I took your secondary query as request for additional comments.
I recommend following the approach in post #2 to insert values in a and b with the implied idea to plot the results to improve understanding. You could write a small generic program to solve and plot similar equations for future use and also to test your expanded equation.
I agree with you that equations of this form resemble polynomials that fall within binomial theory but the encyclopedia reference was also intended as reminder on technique including expansion, geometric analysis, generalizations, and application of transcendental functions particularly natural logarithms. Thanks.
[EDIT 20200218: removed irrelevant comments.]
Just calculate the roots. Any polynomial factorizes into linear factors (over ##\mathbb{C}## of course, not ##\mathbb{R}## though). Here it's very easy
$$a^6-b^6=0$$
has the independent solutions
$$a_k=b \exp(2 \pi \mathrm{i} k/6)=b \exp(\pi \mathrm{i} k/3), \quad k \in \{0,1,2,3,4,5 \}.$$
The factorization reads
$$a^6-b^6=\prod_{k=0}^5 (a-a_k).$$
Likes Klystron
FAQ: Solve Factorization of ##a^6-b^6## - Different Approach
What is factorization?
Factorization is the process of breaking down a mathematical expression into its smaller, simpler components. This is often done to make calculations easier or to find the roots of an equation.
Why is factorization important?
Factorization is an essential concept in mathematics because it allows us to solve equations, find common factors, and simplify complex expressions. It is also used in many fields such as engineering, physics, and computer science.
What is the traditional approach to solving factorization of a6-b6?
The traditional approach to solving factorization of a6-b6 is by using the difference of squares formula, which states that a2-b2 = (a+b)(a-b). In this case, we can rewrite a6-b6 as (a2)3-(b2)3 and apply the formula twice.
What is the different approach to solving factorization of a6-b6?
The different approach to solving factorization of a6-b6 is by using the identity (a3-b3) = (a-b)(a2+ab+b2). By substituting a2 for a and b2 for b, we can rewrite a6-b6 as (a3)2-(b3)2 and apply the identity twice.
Which approach is better for solving factorization of a6-b6?
Both approaches are equally valid and can be used to solve factorization of a6-b6. The choice of approach depends on the specific expression and the individual's preference. It is always a good idea to practice both methods to become proficient in solving various types of factorization problems.
