Solve for $a^2$ in $u_{xx} = u_{tt}$ using $u_1$ and $u_2$
  • MHB
  • Thread starter karush
In summary, we have solved for $a^2 u_{xx} = u_{tt}$ for real number $\lambda$, and determined that $u_1(x,t) = \sin(\lambda x) \sin(\lambda at)$ and $u_2(x,t) = e^{-a^2 \lambda^2 t}\sin(\lambda x)$ are possible solutions. We have also shown that $a^2 u_{xx} = u_{tt}$ holds true for these solutions.
karush
MHB
3,269
Find $a^2 u_{xx} = u_{tt} $ if $\lambda$ a real number.
If
$u_1\left(x, t\right)=\sin\left({\lambda x}\right)\sin\left({\lambda at}\right)$
And
$u_2 \left(x, t\right)={e}^{-a^2 \lambda ^2 t}\sin\left({\lambda x}\right)$
I didn't know how to deal with the $a^2$
If
And
What do you mean "find" this differential equation? Are you trying to solve it? Or are you trying to show that u1 and u2 are possible solutions?
Yes sorry
Are $u^1$ and $u^2$ possible solutions
On the calculator I got
$${u}_{xx}=-\lambda^2\sin\left({\lambda x}\right) $$
So $\alpha$ disappeared
karush said:
Yes sorry
It can't disappear. The entire $\displaystyle \begin{align*} \sin{ \left( \lambda \, a\, t \right) } \end{align*}$ term is a constant when differentiating partially with respect to x.
Since $u_{xx}=-\lambda^2 \sin\left({\lambda x}\right)\sin\left({a\lambda t}\right)$
and
$u_{tt}=-a^2 \lambda^2 \sin\left({\lambda x}\right)\sin\left({a\lambda t}\right)$
Then $a^2 u_{xx}=u_{tt } $
I hope
and
I hope
Yes that is correct :)
Can you do the other part of the question?
FAQ: Solve for $a^2$ in $u_{xx} = u_{tt}$ using $u_1$ and $u_2$
What does "$a^2$" represent in this equation?
In this equation, $a^2$ represents the coefficient of the second derivative of the function $u(x,t)$.
How do you solve for $a^2$ using $u_1$ and $u_2$?
To solve for $a^2$ in this equation, you would first take the second derivative of both $u_1$ and $u_2$ with respect to $x$ and $t$. Then, you would set these derivatives equal to each other and solve for $a^2$.
What is the significance of using $u_1$ and $u_2$ in this equation?
The functions $u_1$ and $u_2$ represent two different solutions to the same differential equation. By setting their second derivatives equal to each other, we can solve for the coefficient $a^2$ that is common to both solutions.
Can you use any other functions besides $u_1$ and $u_2$ to solve for $a^2$?
Yes, you can use any two solutions to the differential equation $u_{xx} = u_{tt}$ in place of $u_1$ and $u_2$ to solve for $a^2$. However, it is important to note that the solutions must be linearly independent in order for this method to work.
Why is solving for $a^2$ important in this equation?
Solving for $a^2$ allows us to determine the value of the coefficient of the second derivative in the differential equation $u_{xx} = u_{tt}$. This information is important in understanding the behavior of the function $u(x,t)$ and finding its general solution.
