Solve for Complex Number \(z\) Given \(4+i(4z+1)=2re^{i(\pi+\theta)}\)
In summary: Please show me the right way if i did not.The equations I get are:\[4r \cos(\theta)+2r \sin(\theta)=-1\] \[2r \cos(\theta)-4r\sin(\theta)=-4\]Which when divided give:\[\frac{2}{-1}=\frac{-4}{-1}\]i.e. the same equation as my solution with the algebraic method.The two equations in \(r\) and \(\theta\) are easily solved for \(r\) and \(\theta\) by equating the square of the first to the square of the second, then rearranging to get a quadratic in \(r^2\
Punch
44
Given \(z=r(cos\theta+isin\theta)\), solve for \(z\) in the form \(a+ib\) if \(4+i(4z+1)=2re^{i(\pi+\theta)}\)
Mathematics news on Phys.org
Re: complex numbers
Use \$ delimiters around in-line LaTeX maths and \$\$ delimiters around display LaTeX maths.
CB
Re: complex numbers
Expand both sides in Cartesian form, remembering that \(e^{i\phi}=\cos(\phi)+i \sin(\phi)\), then equate real and imaginary parts and solve for \(r\) and \( \theta \)
Alternative method: rewrite the left hand side in polar form and equate modulus and arguments.
CB
Re: complex numbers
CB
One question, do i expand z too?
For the cartesian approach yes, it then will give you a pair of simultaneous equations in \(r\) and \(\theta\) to solve.
CB
\[ \displaystyle \begin{align*} 4 + i\left(4z + 1\right) &= 2r\,e^{i\left(\pi + \theta\right)} \\ 4 + i\left(4z + 1\right) &= 2r\left[\cos{\left( \pi + \theta \right)} + i\sin{\left( \pi + \theta \right)} \right] \\ 4 + i\left(4z + 1\right) &= 2r\left[-\cos{\left(\theta\right)} - i\sin{\left(\theta\right)}\right] \\ 4 + i\left(4z + 1\right) &= -2r\left[\cos{\left(\theta\right)} + i\sin{\left(\theta\right)} \right] \\ 4 + i\left(4z + 1\right) &= -2z \end{align*} \]
Now solve for $\displaystyle z$.
I see that there is another method to solve. But could u also show me the method of solving for theta and r?
No.
1) It's longer.
2) It's much more difficult.
3) It's pointless when there is a much more straightforward method such as what I have shown you.
Just write the equations out in Cartesian form, the solution from that point is easier than you might think once you see the form of the equations.
CB
CB
Really? Because that was my first instinct as well, and ended up with two equations in four unknowns...
There are only two unknowns \(r\) and \(\theta\) (even in the Cartesian form of the equations). Eliminate \(r\) by dividing one by the other (after a bit of rearrangement) and you are left with a linear equation in \(\tan(\theta)\) (at least after dividing top and bottom by \(\cos(\theta)\) )
On second thoughts we are talking at cross purposes, I think what you mean is to write the equation as:
\(4+i(4z+1)=-2z\)
and then solve for \(z\) by common algebra and then simplify.
CB
\(4+i(4z+1)=-2z\)
CB
I know what I did wrong now, I had forgotten that we were given $\displaystyle z = r\left[\cos{\left(\theta\right)} + i\sin{\left(\theta\right)}\right]$.
\(4+i(4z+1)=-2z\)
CB
First, I am sorry as i had a problem using the latex... Please do me a favour by helping me to add the latex
Secondly, I tried using this approach and formed 2 equations \( r=\frac{sin(\pi+\theta)-1}{4cos\theta}\) and \(r=\frac{2}{cos9\pi+\theta0+2sin\theta}\)
Dividing one by the other, I formed the equation \(\frac{8}{(-1+2tan\theta)(-sin\theta-1)}=1\) which i couldn't solve for \(\theta\)...
The method is also very long. Did i do it the right way? Please show me the right way if i did not.
\[\frac{2 \cos(\theta)+\sin(\theta)}{\cos(\theta)-2\sin(\theta)}=\frac{1}{4}\]
CB
CB
I will try it again, thanks
---------- Post added at 06:49 PM ---------- Previous post was at 06:19 PM ----------
CB
You're right. However, solving for theta is not the end of the story... The question requires the answer to be presented in the form a+ib. Am I right in saying that tackling the question using this method would take very long? Or is there another way to find a and b after solving for r and theta?
\(a=r \cos(\theta),\ b=r \sin(\theta)\)
CB
FAQ: Solve for Complex Number \(z\) Given \(4+i(4z+1)=2re^{i(\pi+\theta)}\)
What is a complex number?
A complex number is a number that can be written in the form a + bi, where a and b are real numbers and i is the imaginary unit, equal to the square root of -1.
What is the equation "4+i(4z+1)=2re^{i(\pi+\theta)}" asking me to do?
This equation is asking you to solve for the complex number z that satisfies the equation. In other words, you need to find the value of z that makes the left side of the equation equal to the right side.
What is the significance of the exponential term "re^{i(\pi+\theta)}" in the equation?
The exponential term represents a complex number in polar form, where r is the magnitude or distance from the origin and θ is the angle of the complex number in the complex plane. This allows us to represent complex numbers in a visually intuitive way.
How do I solve for z in this equation?
To solve for z, you can start by simplifying the equation using algebraic operations to isolate z on one side of the equation. Then, you can use the properties of complex numbers to solve for z. Alternatively, you can use a graphing calculator or software to plot the equation and find the intersection point, which represents the solution for z.
Are there any restrictions on the values of z that can satisfy this equation?
Yes, there may be restrictions depending on the given values of r and θ. For example, if r is negative, then the value of θ must be in the range of (0, 2π) for the equation to have a solution. Additionally, if r is equal to 0, then the solution for z will be undefined.
