MHB Solve for frequency & angle in dispersion equation
The discussion focuses on solving for frequency (f) and angle (theta) in the equation x = sin[(pi*f*W)/c * sin(theta)] / [(pi*f*W)/c * sin(theta)]. The user seeks assistance due to confusion with the "arcsin of arcsin" concept. It is clarified that W and c are constants, while f and W are variables representing frequency and source width, respectively. The user aims to calculate f and theta based on known values of x, W, and theta, or x, f, and W. The conversation emphasizes the need for mathematical guidance in rearranging the equation for these variables.
NiToNi
OK I'm about to grow (more) gray hairs...
Could some friendly soul smarter than myself kindly help me solve for both f and theta respectively in the following equation, please:
x = sin[ (pi*f*W)/c * sin(theta) ] / [ (pi*f*W)/c * sin(theta) ]
Getting stuck at "arcsin of arcsin" sort of thing...
Many thanks in advance (Nod)
Nick
Mathematics news on Phys.org
Nick
W and c are constant, am I right?
And it should look like $x = \frac{\sin[ \frac{\pi \cdot f \cdot W}{c}\ \cdot \;\sin(\theta) ] }{ \frac{\pi \cdot f \cdot W}{c}\ \cdot \;\sin(\theta)}$ ?
Hi Mathick,
Thanks for your reply :)
Your rearranging is correct - that's what it should look like.
However f and W are not constants per se. f is frequency (Hz) and W is source width (m), both of which are (positive) variables.
What I probably should have said though is that x is a ratio (power factor) so values are between 0 and 1:
0 < x < 1
As the equation is arranged now, I can calculate the power factor (x) knowing f, W and theta. What I am trying to do is solve also for f and W so I can calculate:
a. f knowing x, W and theta;
b.theta knowing x, f and W
Does thatn make sense?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
