MHB Solve for $\overline{abc}:$ $N=3194$
  • Thread starter Thread starter Albert1
The problem involves finding the three-digit number $\overline{abc}$ such that the sum of the permutations $\overline{acb}+\overline{bac}+\overline{bca}+\overline{cab}+\overline{cba}$ equals 3194. The total sum of these permutations is expressed as $222(a+b+c)$, which must be a multiple of 222 and lie between 3194 and 4194. The valid multiples of 222 in this range are 3330, 3552, 3774, and 3996, corresponding to potential values of $\overline{abc}$. The only solution that satisfies both the sum condition and the digit sum condition is $\overline{abc} = 358$, where $3+5+8 = 16$. Thus, the final answer is $\overline{abc} = 358$.
Albert1
if $N=\overline{acb}+\overline{bac}+\overline{bca}+\overline{cab}+\overline{cba}=3194$ is the sum of five 3-digit numbers
please find :$\overline{abc}$
(here $\overline{abc}$ is also a 3-digit number)
Mathematics news on Phys.org
[sp]The sum of all six numbers is $(100 + 10 + 1)(2a+2b+2c) = 222(a+b+c)$, so it has to be a multiple of $222$. Also, it has to lie between $3194$ and $4194$. The only multiples of $222$ in that range are $$\begin{aligned} 3330\ &= 15\times 222 \text{, corresponding to } \overline{abc} = 3330 - 3194 = 136, \\ 3552\ &= 16\times 222 \text{, corresponding to } \overline{abc} = 3552 - 3194 =358, \\ 3774\ &= 17\times 222 \text{, corresponding to } \overline{abc} = 3774 - 3194 =580, \\ 3996\ &= 18\times 222 \text{, corresponding to } \overline{abc} = 3996 - 3194 = 802. \end{aligned}$$ Also, the sum $a+b+c$ must be equal to the corresponding multiple of $222$. The only case where this occurs is when $\boxed{\overline{abc} = 358} = 16\times 222$, with $3+5+8 = 16$.[/sp]
Opalg said:
[sp]The sum of all six numbers is $(100 + 10 + 1)(2a+2b+2c) = 222(a+b+c)$, so it has to be a multiple of $222$. Also, it has to lie between $3194$ and $4194$. The only multiples of $222$ in that range are $$\begin{aligned} 3330\ &= 15\times 222 \text{, corresponding to } \overline{abc} = 3330 - 3194 = 136, \\ 3552\ &= 16\times 222 \text{, corresponding to } \overline{abc} = 3552 - 3194 =358, \\ 3774\ &= 17\times 222 \text{, corresponding to } \overline{abc} = 3774 - 3194 =580, \\ 3996\ &= 18\times 222 \text{, corresponding to } \overline{abc} = 3996 - 3194 = 136. \end{aligned}$$ Also, the sum $a+b+c$ must be equal to the corresponding multiple of $222$. The only case where this occurs is when $\boxed{\overline{abc} = 358} = 16\times 222$, with $3+5+8 = 16$.[/sp]
very nice solution!
almost same method solved at
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
