Solve for Positive Integer Solutions
In summary, the conversation discussed finding all values of $(a,\,b)$ that are positive integers for which $\dfrac{a^2+b^2}{a-b}$ is an integer and divides 1995. The solution involves finding factors $k$ of 1995 such that $2k^2$ is a sum of two squares. The only factor congruent to $1$ mod $4$ is $5$, which gives the solution $(a,b) = (3,1)$. This can be multiplied by other factors of 1995 to get the remaining solutions of $(a,b) = (9,3),\ (21,7),\ (57,19),\ (63,21),
anemone
MHB
POTW Director
3,883
115
Find all values of $(a,\,b)$ where they are positive integers for which $\dfrac{a^2+b^2}{a-b}$ is an integer and divides 1995.
Mathematics news on Phys.org
[sp]If $\frac{a^2+b^2}{a-b} = k$, then $a^2+b^2 = k(a-b)$. Multiply by $4$ and complete the square, to get $(2a-k)^2 + (2b+k)^2 = 2k^2.$ We want to find factors $k$ of $1995 = 3\cdot 5\cdot 7 \cdot 19$ such that $2k^2$ is a sum of two squares. Now the only way that a number can be expressed as the sum of two distinct squares is if it has factors congruent to $1$ mod $4$. The only such factor in $1995$ is $5$. If we put $k=5$ then $2k^2 = 50 = 1^2 + 7^2$. Putting $2a-5=1$ and $2b+5 = 7$, we get the solution $(a,b) = (3,1).$ The only other solutions will occur through multiplying this basic solution by another factor of $1995.$ Those factors are $3,7,19,21,57,133$ and $399$. Thus there are eight solutions altogether namely $$(a,b) = (3,1),\ (9,3),\ (21,7),\ (57,19),\ (63,21),\ (171,57),\ (399,133),\ (1197,399).$$[/sp]
Bravo, Opalg! (Cool)(Clapping)(Sun) And thanks for participating!:)
FAQ: Solve for Positive Integer Solutions
What is the definition of a positive integer?
A positive integer is a whole number that is greater than zero and does not have any decimal or fractional parts. It can be represented as 1, 2, 3, 4, and so on.
How do you solve for positive integer solutions in an equation?
The first step is to identify the equation and determine the unknown variable. Then, use algebraic operations such as addition, subtraction, multiplication, and division to isolate the variable on one side of the equation. Finally, substitute positive integer values for the variable and solve for the other unknown values.
Can a positive integer solution be a negative number?
No, a positive integer solution must be a whole number that is greater than zero. Negative numbers are not considered to be positive integers.
Are there any limitations to solving for positive integer solutions?
Yes, there are limitations to solving for positive integer solutions. The equation must have only one variable and the operations used must be allowed for positive integers. Also, the equation must have a finite number of solutions.
How do positive integer solutions differ from real number solutions?
Positive integer solutions are limited to whole numbers that are greater than zero, while real number solutions can include any number on the number line, including fractions and decimals. Additionally, real number solutions can be positive, negative, or zero, while positive integer solutions must be greater than zero.
