Solve for positive integer solutions
In summary, the conversation discusses solving for positive integers $x$ and $y$ in an equation, where the left side is factored and the prime common divisor is used to show that no solutions exist. The solution involves proving that $x-y$ and $x+y+1$ are coprime, and then using this to show that no positive integer solutions can exist.
anemone
MHB
POTW Director
3,883
115
Solve for positive integers $x$ and $y$ where $x^2+x=y^3+y^2+y$.
Mathematics news on Phys.org
Trick question?
Pretty sure there's no solution to that.
2x = -1 + SQRT[1 + 4y(y^2 + y + 1)]
Tu est cruel, Anemone!
Wilmer said:
Trick question?
No, that is a genuine contest problem and solver is expected to convince us why the above equation has no solutions. (Malthe)
Au fait, Je suis tout mignon et gentil.:p
needs closure
My solution:
Note that $x^2+x=x(x+1)$ is the product of two consecutive positive integers whereas $y^3+y^2+y=y(y^2+y+1)$ can never represent the product of two consecutive positive integers. So we can conclude the problem has no solution.
anemone said:
My solution:
I'm not saying you are wrong, anemone, but your argument doesn't hold for something like the case 8 * 9 = 4 * 18. No one says that the x function and y function have to give the same pair of factors.
-Dan
[sp]Write the equation as $x^2 - y^2 + x - y = y^3.$ The left side factorises, giving $(x-y)(x+y + 1) = y^3.$ Suppose that $p$ is a prime common divisor of $x-y$ and $x+y+1$. Then $p$ also divides their product $y^3$ and therefore $p$ divides $y$. So $p$ divides $(x-y)+2y = x+y$. It follows that $p$ cannot divide $x+y+1$, contradicting the initial assumption about $p$.
That contradiction shows that no such $p$ can exist, and therefore $x-y$ and $x+y+1$ are coprime. But their product is a cube, and so they must each individually be cubes, say $x-y = u^3$ and $x+y+1 = v^3$, where $u,v$ are integers with $v>u>0.$ Also, $u^3v^3 = y^3$ so that $y=uv.$
Thus $x-uv = u^3$ and $x + uv + 1 = v^3$. Hence $(u^3 + uv) + uv + 1 = v^3$, from which $$2uv+1 = v^3 - u^3 = (v-u)(v^2 + uv + u^2).$$ But $v-u \geqslant 1$ and hence $v^2 + uv + u^2 \leqslant 2uv+1.$ Therefore $$0 < (v-u)^2 = v^2 - 2uv + u^2 = (v^2 + uv + u^2) - 3uv \leqslant (2uv+1) - 3uv = 1 - uv <0.$$ That is another contradiction, and the conclusion this time is that no positive integer solution $(x,y)$ to the original equation can exist.[/sp]
Thanks Opalg for participating and thanks for the smart solution!(Cool)
FAQ: Solve for positive integer solutions
What does "solve for positive integer solutions" mean?
"Solve for positive integer solutions" means finding values for a given equation or problem that result in positive whole numbers as the solution. This is often used in math and science to find the most practical and realistic solutions.
What types of problems can be solved using positive integer solutions?
Problems that involve finding the number of items, determining the number of possible combinations, or solving equations with variables can all be solved using positive integer solutions. Some common examples include counting problems, optimization problems, and algebraic equations.
What is the difference between positive integer solutions and real number solutions?
The main difference is that positive integer solutions are limited to whole numbers, while real number solutions can include any number on the number line, including fractions and decimals. Real number solutions are often used in more complex math and science problems, while positive integer solutions are more commonly used in basic calculations and counting problems.
How do you know if a solution is a positive integer solution?
A solution is considered a positive integer solution if it is a whole number that is greater than zero. This can be determined by plugging in the values into the original equation or problem and checking that the solution meets the criteria of being a positive integer.
Why are positive integer solutions important in science?
Positive integer solutions are important in science because they help us find practical and realistic solutions to problems that involve counting, measuring, and optimizing. They also allow us to simplify complex equations and make them more manageable. In addition, positive integer solutions can provide insight into patterns and relationships in nature, which can lead to further discoveries and advancements in science.
