Solve for r,t in the Polynomial $3x^3+rx^2+sx+t=0$ with a,b,c Prime
In summary, the variables $a,b,c$ are natural numbers and satisfy the equations $c+1=2a^2$ and $c^2+1=2b^2$, where $c$ is a prime number. They are also the roots of the cubic equation $3x^3+rx^2+sx+t=0$. The values of $r$ and $t$ are $-42$ and $-210$, respectively. The only solution for $a,b,c$ is $a=2, b=5, c=7$.
Albert1
1,221
$a,b,c \in N$
$c+1=2a^2$
$c^2+1=2b^2$
c is a prime
a,b,c are roots of $ 3x^3+rx^2+sx+t=0 $
please find r and t
Mathematics news on Phys.org
Re: find f and t
It may not be an ellegent one i just gave it a shot$$
\begin{align*}c^2+2c+1&=4a^4\\c&=2a^4-b^2\end{align*}$$
I gave a try at a=2 so b is 5 and c is 7.
And 7 is also the first prime to satisfy both equations even individually too.
So r is -52 and t is -210
Re: find f and t
Albert said:
$a,b,c \in N$
$c+1=2a^2$
$c^2+1=2b^2$
c is a prime
please find r and t
[sp]One solution is $a=2$, $b=5$ and $c=7$. Since $a+b+c = -r/3$ and $abc = -t/3$, that gives $r=-42$ and $t=-210$. But is that the only solution?
I think that it is, but I can't prove it. In fact, the equation $c^2+1=2b^2$ can be written $\bigl(\frac cb\bigr)^2 + \bigl(\frac 1b\bigr)^2 = 2$, so that $c/b$ is a lower convergent for $\sqrt2$. The condition $c+1=2a^2$ requires that $\frac12(c+1)$ is a square, and the only Pell number less than $10^9$ satisfying that condition is $7$. So any other solution for $c$ must be bigger than that.[/sp]
Re: find f and t
$a,b,c\in N,\,\, c:a\,\, prime$
$c+1=2a^2---(1)$
$c^2+1=2b^2---(2)$
(2)-(1):$c(c-1)=2(b-a)(b+a)---(3)$
from (1)(2)(3) we conclude :
$c\geq b \geq a,\,\, and \,\,\,\, c \mid (a+b),( or\,\, (a+b) \,\, mod \,\, c=0)--(4)$
$\therefore c=a+b, \rightarrow b=c-a$
from (3)
$c-1=2b-2a=2(c-a)-2a=2c-4a$
$\therefore c+1=4a=2a^2$
$\therefore a=2,c=7,b=5$
$\therefore r=-3\times (2+5+7)=-42,\,\, t=-3\times(2\times5\times7)=-210$
To solve for r and t, we can use the fact that a,b,c are roots of the polynomial, meaning that when we substitute them into the equation, the equation will equal 0.
Substituting a into the equation, we get:
$3a^3+ra^2+sa+t=0$
Substituting b into the equation, we get:
$3b^3+rb^2+sb+t=0$
Substituting c into the equation, we get:
$3c^3+rc^2+sc+t=0$
We can use this information to create a system of equations:
$3a^3+ra^2+sa+t=0$
$3b^3+rb^2+sb+t=0$
$3c^3+rc^2+sc+t=0$
We can then solve for r and t by using any method of solving systems of equations, such as substitution or elimination.
Using substitution, we can solve for r:
From the first equation, we can solve for t:
$t=-3a^3-ra^2-sa$
Substituting this into the second equation:
$3b^3+rb^2+sb-3a^3-ra^2-sa=0$
Simplifying:
$3b^3+rb^2+sb-3a^3-ra^2=0$
Factoring out r:
$r(b^2-a^2)+s(b-a)=0$
Since a and b are distinct primes, we know that b-a cannot equal 0. Therefore, we can divide both sides by b-a:
$r=\frac{-s}{b-a}$
Now, using this value of r, we can solve for t by substituting it into the first equation:
$t=-3a^3-\frac{s}{b-a}a^2-sa$
Simplifying:
$t=-3a^3-\frac{s}{b-a}a^2-\frac{sa(b-a)}{b-a}$
$t=-3a^3-\frac{s}{b-a}a^2-\frac{sab-sa^2}{b-a}$
$t=-3a^3-\frac{sab}{b-a}$
$t=-\frac{3a^3(b-a)+s
FAQ: Solve for r,t in the Polynomial $3x^3+rx^2+sx+t=0$ with a,b,c Prime
What is the purpose of solving for r and t in this polynomial?
The purpose of solving for r and t in this polynomial is to find the values for the variables that will make the equation true. This will allow for a more complete understanding and analysis of the polynomial and its properties.
How do you solve for r and t in this polynomial?
To solve for r and t, you can use techniques such as factoring, the quadratic formula, or synthetic division. It is important to use the prime values of a, b, and c in order to find the most accurate solutions for r and t.
What is the significance of a, b, and c being prime in this polynomial?
The fact that a, b, and c are prime in this polynomial means that they are only divisible by 1 and themselves. This can simplify the solving process and ensure that the solutions for r and t are unique and not affected by other factors.
Can you solve for r and t if a, b, or c are not prime?
Yes, it is possible to solve for r and t if a, b, or c are not prime. However, the solutions may not be as straightforward and may involve more complex techniques such as completing the square or using the cubic formula.
How many solutions are there for r and t in this polynomial?
Since this is a cubic polynomial, there can be up to three solutions for r and t. However, it is also possible to have fewer solutions or no real solutions at all depending on the values of a, b, and c.
