MHB Solve for Rational Term: 2x^2-1 Over x^2+1
  • Thread starter Thread starter theakdad
    Rational Term
The expression $$\frac{2x^2-1}{x^2+1}$$ simplifies to $$2-\frac{3}{x^2+1}$$ through polynomial long division. By dividing the numerator by the denominator, the quotient is 2, and the remainder is -3, leading to the final expression. This method is similar to dividing numbers, where the remainder is factored into the result. Alternative approaches yield the same conclusion, confirming the validity of the simplification. Understanding this process enhances problem-solving skills for similar algebraic expressions.
theakdad
I have a question why is $$\frac{2x^2-1}{x^2+1}$$ equal to $$2-\frac{3}{x^2+1}$$ ??
Mathematics news on Phys.org
wishmaster said:
U have a question why is $$\frac{2x^2-1}{x^2+1}$$ equal to $$2-\frac{3}{x^2+1}$$ ??
\begin{aligned}
&= \frac{2x^2 + 2 - 3}{x^2+1} \\
&= \frac{2(x^2 + 1) - 3}{x^2+1} \\
&= \frac{2(x^2 + 1)}{x^2+1} - \frac 3{x^2+1}\\
&= 2-\frac{3}{x^2+1} \\
\end{aligned}
I like Serena said:
\begin{aligned}
\end{aligned}
thank you!
Is this the only way to caclulate it?
wishmaster said:
thank you!
It is similar to calculating:
\begin{aligned}
\frac 7 2
&= \frac {3\cdot 2 + 1}{2} \\
&= \frac {3\cdot 2} 2 + \frac{1}{2} \\
&= 3 + \frac 1 2
\end{aligned}
Just with more complicated expressions.Alternatively, you can say that if you divide $7$ by $2$, you get $3$ with a remainder of $7 - 3 \cdot 2 = 1$.
That is, $$\frac 7 2 = 3 + \frac 1 2$$.Similarly, you can say that if you divide $2x^2-1$ by $x^2 +1$, you get $2$, because the coefficient of $x^2$ is $2$.
The remainder is then $(2x^2 - 1) - 2(x^2+1) = 2x^2 - 1 - 2x^2 - 2 = -3$.
So
$$\frac{2x^2-1}{x^2+1} = 2 + \frac {-3}{x^2+1}$$
Note that this "other" method is really the same thing.
Hello, wishmaster!
\text{Why is }\,\frac{2x^2-1}{x^2+1}\,\text{ equal to }\,2-\frac{3}{x^2+1}\,?
Are you familiar with Long Division?
. . \begin{array}{cccccc}<br /> &amp;&amp;&amp;&amp; 2 \\<br /> &amp;&amp; --&amp;--&amp;-- \\<br /> x^2+1 &amp; | &amp; 2x^2 &amp;-&amp;1 \\<br /> &amp;&amp; 2x^2 &amp;+&amp; 2 \\<br /> &amp;&amp; --&amp;--&amp;-- \\<br /> &amp;&amp;&amp; - &amp; 3 \end{array}Therefore: .\frac{2x^2-1}{x^2+1} \;\;=\;\;2 - \frac{3}{x^2+1}
soroban said:
Hello, wishmaster!
Thank you all for the help! I have studied those kind of problems,so now i know how to do it!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
