Solve for $x$ and $y$: Real Number Condition
  • MHB
  • Thread starter anemone
  • Tags
    Condition
In summary, for two positive real numbers $x$ and $y$ that satisfy the condition $x^3=x+1$ and $y^6=3x+y$, it can be proven that $x>y$ by finding the solution for both equations and comparing their values. This method does not use graphical representation and is an alternative solution to the problem.
anemone
MHB
POTW Director
3,883
115
For two positive real numbers $x$ and $y$ that satisfy the condition $x^3=x+1$ and $y^6=3x+y$, show that $x>y$.
Mathematics news on Phys.org
$x^3=x+1----(1)$ and
$y^6=3x+y---(2)$
from (1)(2):
1<x<2 , 1<y<2(for x,y>0)
if we want to prove x>y we only have to prove :$x^6>y^6$
that is to prove :$x^2+2x+1>3x+y$
$=>x^2-x+1>y$
from the diagram x=y is the tangent line of $x^2-x+1 $ at point (1,1)
when x>1 then $y=x^2-x+1$ is all above $y=x$
and the prove x>y is done.
$y^6=3x+y---(2)$
from (1)(2):
$=>x^2-x+1>y$
$x^ 2 −x+1$ is all above y=x means x >y means it is rue but it does not mean that x >y $
consider the range when x>1 then we set:
$y_1=x^2-x+1$
$y_2=x$
compare $y_1 $ and $ y_2$(for the same $x$)
$y_1=x^2-x+1$
$y_2=x$
if y < x this is true agreed
but x = 1.7 and y = 1.8 means
x^2 - x + 1 = 2.19 > y even though y is > x we need to prove y < x and not the other way around
from $x^3=x+1----(1)$
$y^6=3x+y--------(2)$
at first you must find the solution of (1)
and put the soluion x to (2) and find the solution of y and compare the value of x and y
so x and y must both meet the restriction of (1) and (2)
this can be said as find the solution of (1) and (2) and compare its value
are you sure x=1.7 and y=1.8 will satisfy (1) and (2) ?
the value of y is based on the same value of x in (1)
$x^3 =x+1−−−−(1)$
x has to be > 1 as $x^3>= 1$ and if
$x^3 - x - 1= x^2(x-1) - 1$ is monotonically increasing for x > 1
as x = 2 => $x^3 - x -1 = 5$ > 0 so x is between 1 and 2
$y^ 6 =3x+y$
$y^6$ > 1 so y > 1
as x < 2 so $y^6 - y < 6$ and y < 2 because $y^6- y$ monotonically increasing for y > 1 and for y = 2 it is 62
to show x > y we need to prove $x^6 > y^6$
or $x^2 +2x+1>3x+y$
=>$x 2 −x+1>y$
now $x 2 −x+1 = (x-1)^2 + x + 1$ > 2 ( as x > 1) > y
hence proved
edit: above is mistake
based on comment by Albert $x 2 −x+1 = (x-1)^2 + x $
it is > x and without proving x > y we cannot prove it > y so we are back to square one. I am sorry and thanks to Albert
kaliprasad said:
$x^3 =x+1−−−−(1)$
$y^ 6 =3x+y$
$y^6$ > 1 so y > 1
or $x^2 +2x+1>3x+y$
=>$x 2 −x+1>y$
hence proved
you said : $x 2 −x+1 = (x-1)^2 + x + 1$
but :$x^ 2 −x+1 \neq (x-1)^2 + x + 1$
Yes .It is my mistake
$y^6=3x+y---(2)$
from (1)(2):
$=>x^2-x+1>y$
Well done, Albert! And thanks for participating!:)
Here is another solution that I saw online that doesn't use the graphical method for proving the result and hence I will share it:
Note that $x^3>1$ which implies $x>1$ and $y^6>y$ and $\therefore y>1$.
Also, $x^6=x^2+2x+1 \ge 4x$ so we have $x^6-y^6 \ge 4x-y-3x=x-y$
$x^6-y^6 \ge x-y$
$(x-y)(x^5+x^4y+x^3y^2+x^2y^3+xy^4+y^5) \ge x-y$
If $x<y$, we have $(x^5+x^4y+x^3y^2+x^2y^3+xy^4+y^5) \le 1$ for all $x,\,y>0$ and this is clearly impossible.
If $x=y$, we have $x^5=4$ and $x^6=x^2+2x+1$ and we get $4x=x^2+2x+1$ which yields $x=1$ and this leads a contradiction since $x>1$.
So it must be $x>y$ that holds and we're done.
FAQ: Solve for $x$ and $y$: Real Number Condition
What is the real number condition in solving for x and y?
The real number condition in solving for x and y is the requirement that the solutions for both variables must be real numbers. In other words, the solutions must be numbers that can be expressed on the number line, including whole numbers, fractions, decimals, and irrational numbers.
How do I determine if a solution is a real number?
To determine if a solution is a real number, you can graph the equations or plug the values into the original equations. If the resulting value is a real number, then it satisfies the real number condition.
Can a solution be both a real number and an imaginary number?
No, a solution cannot be both a real number and an imaginary number. The real number condition only allows for real numbers as solutions.
What happens if there are no real number solutions?
If there are no real number solutions, then the equations do not intersect and there is no point of intersection. This means that there is no solution that satisfies both equations and the system is considered inconsistent.
Is the real number condition the same for all types of equations?
Yes, the real number condition applies to all types of equations, including linear, quadratic, exponential, and logarithmic equations. In all cases, the solutions for x and y must be real numbers in order to satisfy the real number condition.
