Solve for $x$: Find Value of x
  • MHB
  • Thread starter Albert1
  • Tags
    Value
In summary, "solving for x" means finding the numerical value of x in an equation or expression. This is done by using algebraic techniques such as combining like terms, isolating x on one side of the equation, and using inverse operations to simplify the equation until x is the only remaining variable. Some common mistakes when solving for x include not performing the same operation on both sides of the equation and forgetting to use the inverse operation. There are also special cases, such as quadratic equations or equations with fractions, where more advanced algebraic techniques may be needed to solve for x. It is important to carefully analyze the equation and choose the appropriate method for solving.
Albert1
1,221
find:$x$
$x^2+\dfrac {9x^2}{(x-3)^2}=16$
Mathematics news on Phys.org
Re: find x
My workable but a bit tedious solution(Tongueout):
By dividing both sides of the equation by $x^2$, we get:
$1+\left( \dfrac{3}{x-3} \right)^2=\left( \dfrac{4}{x} \right)^2$
Let $\dfrac{3}{x-3}=\tan y$, $\therefore\dfrac{4}{x}=\dfrac{4\tan y}{3(1+\tan y)}$ and the equation above becomes
$1+\tan^2 y=\left( \dfrac{4\tan y}{3(1+\tan y)} \right)^2$, which after simplification, we get
$\sec y= \dfrac{4\tan y}{3(1+\tan y)} $.
By rewriting $\sec y= \dfrac{4\tan y}{3(1+\tan y)} $ as another equation that involves only $\sin y$ and $\cos y$, we obtain
$3(\sin y+\cos y)=4\sin y \cos y$
Solving it by squaring both sides of the equation we have
$4\sin^2 2y-9\sin 2y-9=0$
$\sin 2y=3$ or $\sin 2y=-\dfrac{3}{4}$ (Since $\sin 2y\le 1$, $\sin 2y=-\dfrac{3}{4}$ is the only solution.)
$\sin 2y=-\dfrac{3}{4}$ tells us $2y$ lies in the third and fourth quadrant.
For $2y$ that lies in the third quadrant:For $2y$ that lies in the fourth quadrant:
$\tan 2y=\dfrac{3}{\sqrt{7}}$$\tan 2y=-\dfrac{3}{\sqrt{7}}$
$\dfrac{2\tan y}{1-\tan^2 y}=\dfrac{3}{\sqrt{7}}$
Solving the equation for $\tan y$ and takes only the negative result, we see that
$\tan y=\dfrac{4-\sqrt{7}}{3}$
By replacing $\tan y=\dfrac{4-\sqrt{7}}{3}$ into $\dfrac{3}{x-3}=\tan y$, we get the value of $x$ as
$x=\sqrt{7}-1$
$\dfrac{2\tan y}{1-\tan^2 y}=-\dfrac{3}{\sqrt{7}}$
By replacing $\tan y=\dfrac{\sqrt{7}-4}{3}$ into $\dfrac{3}{x-3}=\tan y$, we get the value of $x$ as
$x=-\sqrt{7}-1$
Re: find x
thanks ! your solution is correct ( a bit tedious solution as you said )
I think you are very good at trigonometry:)
Re: find x
Thanks for the compliment, Albert! You just made my day! And I think you're really good at geometry!:)
Re: find x
Solution without trigonometry:
The given equation can be written as
$$\left(x+\frac{3x}{x-3}\right)^2-\frac{2\cdot x\cdot 3x}{x-3}=16$$
$$\Rightarrow \left(\frac{x^2}{x-3}\right)^2-\frac{6x^2}{x-3}-16=0$$
Let $\frac{x^2}{x-3}=t$. Hence, we have:
$$t^2-6t-16=0$$
Solving we get, $t=8,-2$.
Case i), when $t=8$,
$$\frac{x^2}{x-3}=8 \Rightarrow x^2-8x+24=0$$
Clearly, the above equation has no solution as the discriminant is less than zero.
Case ii), when $t=-2$,
$$\frac{x^2}{x-3}=-2 \Rightarrow x^2+2x-6=0$$
Solving for x, we get, $x=-1+\sqrt{7},-1-\sqrt{7}$.
Re: find x
$$t^2-6t-16=0$$
very good :)
FAQ: Solve for $x$: Find Value of x
What does it mean to "solve for x"?
"Solving for x" means finding the numerical value of x in an equation or expression. In other words, it is the process of determining what number or variable satisfies the given equation.
How do you solve for x?
To solve for x, you need to use algebraic techniques such as combining like terms, isolating x on one side of the equation, and using inverse operations to get x by itself. The goal is to simplify the equation until x is the only remaining variable on one side.
Can you give an example of solving for x?
Of course! Let's say we have the equation 2x + 4 = 10. To solve for x, we first need to isolate x on one side of the equation. We can do this by subtracting 4 from both sides, which gives us 2x = 6. Then, we divide both sides by 2 to get x = 3. Therefore, the value of x in this equation is 3.
What are some common mistakes when solving for x?
One common mistake is not performing the same operation on both sides of the equation. For example, if you add 3 to one side, you must also add 3 to the other side. Another mistake is forgetting to use the inverse operation when isolating x. For instance, if the equation is 2x + 4 = 10, you must subtract 4 from both sides, not add 4 to both sides.
Are there any special cases when solving for x?
Yes, there are some special cases such as when the equation is quadratic or involves fractions. In these cases, you may need to use more advanced algebraic techniques, like factoring or clearing the fractions, to solve for x. It is important to carefully analyze the equation and choose the appropriate method for solving.
