Solve Gaussian Integrals: QFT Explained & Math Book for Physicists
In summary, the conversation discusses Gaussian integrals in QFT and how Aij is a local operator. The formula for the propagator G(x-y)=-iA^{-1}_{xy} is also mentioned, along with the question of how it doesn't seem to vanish for non-infinitesimal distances. The conversation also briefly mentions a book recommendation for improving the math skills of physics students.
RedX
970
This is probably an easy question, but my math is not good enough to answer it.
For Gaussian integrals:
[tex]\frac{\int \Pi_i [dx_i] x_k x_l e^{-\frac{x_i A_{ij} x_j}{2}}} {\int \Pi_i [dx_i] e^{-\frac{x_i A_{ij} x_j}{2}}}=A^{-1}_{kl} [/tex]
As far as I understand it, in QFT, Aij is a local operator. So Aij might be at most block diagonal, with very tiny sub-blocks corresponding to derivative terms (to know the derivative you only need to know the field an infinitismal distance away). Hence A-1ij should be block diagonal too, with tiny sub-blocks of the same dimension.
So how is it that the propagator [tex]G(x-y)=-iA^{-1}_{xy} [/tex] doesn't seem to vanish for (x-y) not infinitismal?
Also does anyone know of a good math book written for improving the math of physics students?
I don't think this is true.
Yeah. The matrix A was never block diagonal to begin with: I don't know what I was thinking there. Just because it has only nearest neighbors on the diagonals doesn't mean it's block diagonal. So I think in general the inverse is global.
Hassani has a text on mathematics for physicists that quite complete and fairly modern and well written.
FAQ: Solve Gaussian Integrals: QFT Explained & Math Book for Physicists
What is QFT?
QFT stands for quantum field theory, which is a theoretical framework used to describe the interactions between particles at a quantum level. It combines principles from quantum mechanics and special relativity to provide a mathematical description of how particles interact and behave.
What are Gaussian integrals?
Gaussian integrals are mathematical expressions that involve the integration of a Gaussian (bell-shaped) curve. They are commonly used in quantum field theory to calculate the probabilities of different particle interactions and to solve complex equations.
Why are Gaussian integrals important in QFT?
In quantum field theory, Gaussian integrals are used to simplify complicated equations and make them more manageable. They also provide a way to calculate the probabilities of different particle interactions, which is essential in understanding the behavior of particles at a quantum level.
How are Gaussian integrals solved?
Gaussian integrals can be solved using various mathematical techniques, such as completing the square, integration by parts, and change of variables. In QFT, these integrals are often solved using the Feynman path integral method, which involves summing over all possible paths that particles can take in a given interaction.
Is "Solve Gaussian Integrals: QFT Explained & Math Book for Physicists" suitable for beginners?
This book is primarily aimed at physicists and scientists who have a basic understanding of quantum field theory and mathematics. It may be challenging for beginners to understand without some prior knowledge in these areas.
