MHB Solve Integer Equation: 3x+5y=2xy-1
  • Thread starter Thread starter kaliprasad
    Integer
The integer equation 3x + 5y = 2xy - 1 can be transformed by multiplying by 2 and rearranging to yield 4xy - 6x - 10y = 2. This can be factored into (2x - 5)(2y - 3) = 17. Given that 17 is a prime number, there are four possible integer solutions for (x, y): (11, 2), (3, 10), (-6, 1), and (2, -7). The discussion emphasizes the factorization method to find these integer pairs. The approach confirms that different starting points can lead to the same solutions.
kaliprasad
MHB
Solve in integers $3x + 5y = 2xy - 1$
Mathematics news on Phys.org
[sp]
Multiply by $2$ and rearrange: $4xy - 6x - 10y = 2.$
Factorise: $(2x-5)(2y-3) = 17.$
Since $17$ is prime, there are just four possible cases:
1) $\quad 2x-5 = 17$, $2y-3 = 1$, giving $(x,y) = (11,2).$
2) $\quad 2x-5 = 1$, $2y-3 = 17$, giving $(x,y) = (3,10).$
3) $\quad 2x-5 = -17$, $2y-3 = -1$, giving $(x,y) = (-6,1).$
4) $\quad 2x-5 = -1$, $2y-3 = -17$, giving $(x,y) = (2,-7).$
[/sp]
Opalg said:
[sp]
[/sp]
My starting point is different and it becomes same as above
We have $2xy - 3x - 5y - 1 = 2( x - \frac{5}{2}) ( y - \frac{3}{2}) - 1 - \frac{15}{2} = 0$
or $ 2 ( 2x - 5) (2y - 3) = 2 * 17$
or $( 2x - 5) (2y-3) = 17$
Note that LHS is odd and so is RHS.
giving 4 solutions
$2x- 5 = -1, 2y -3= -17$ or $x = 2, y = - 7$
$2x -5 = -17, 2y -3= -1$ or $x = -6, y = 1$
$2x- 5 = 1, 2y -3= 17$ or $x = 3, y = 10$
$2x -5 = 17, 2y -3= -1$ or $x = 11, y = 2$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
