Solve Laplace Eqn W/Derivative Boundary Condition
In summary, we discussed the solving of the Laplace's equation $\nabla^2u = 0$ on a rectangle with various boundary conditions, including one defined by a derivative. We determined that the first boundary condition is redundant and can be replaced with $u(x,0) = h(x)$, where $h(x)$ is a function of $x$. We then solved the Laplace's equation separately for two sets of boundary conditions, $u(x,0) = h(x)$ and $u(x,0) = 0$, and found that the solution to the original problem is the sum of these two solutions. We also provided a general solution for the new boundary conditions and showed how to obtain the correct coefficients for
Dustinsfl
2,281
Consider Laplace's equation $\nabla^2u = 0$ on the rectangle with the following boundary conditions:
u_y(x,0) = f(x)\quad u(L,y) = 0\quad u(x,H) = 0\quad u(0,y) = g(y).
How does one of the boundary conditions being defined by a derivative alter the solving of this problem? I have never done a Laplace equation with derivative BC.
Hi dwsmith, :)
Let me suggest a way to solve this problem. The first boundary condition is redundant and you can replace it with \(u(x,0)=h(x)\). Then you will have to solve the Laplace's equation separately for boundary conditions,
\[u_{1}(x,0) = f(x)\quad u_{1}(L,y) = 0\quad u_{1}(x,H) = 0\quad u_{1}(0,y) = 0\]
and
\[u_{2}(x,0) = 0\quad u_{2}(L,y) = 0\quad u_{2}(x,H) = 0\quad u_{2}(0,y) = g(y)\]
The solution to the original problem will then be,
\[u(x,y)=u_{1}(x,y)+u_{2}(x,y)\]
Further details of this method can be found >>here<<.
Kind Regards,
Sudharaka.
Sudharaka said:
Hi dwsmith, :)
and
Kind Regards,
Sudharaka.
So we can disregard the fact that it is a partial derivative?
I think you are referring to the first boundary condition. When you differentiate \(u(x,y)\) with respect to \(y\) and then substitute \(y=0\) it is obvious that you get a function of \(x\) since we have substituted for \(y\). Hence I don't see any usefulness in that boundary condition. In other words, even if it's not given we know that \(u_{y}(x,0)=\mbox{a function of }x\). So we don't know anything about \(u(x,0)\) except the fact that it's a function of \(x\).
The 'classical' approach permits to find a solution in the form...
$\displaystyle u(x,y)= v(x)\ w(y)$ (1)
... and consists in several steps. The first step is to compute from (1)...
$\displaystyle \frac{\partial^{2} u}{\partial^{2} x}= v^{'\ '} (x)\ w(y)\ ,\ \frac{\partial^{2} u}{\partial^{2} y}= v(x)\ w^{'\ '} (y)\ $ (2)
... that permits to write the original PDE as a pair of ODE...
$\displaystyle \frac{v^{'\ '}(x)}{v(x)}= - \frac{w^{'\ '}(y)}{w(y)}= \lambda$ (3)
... where $\lambda$ is a constant. Then, as suggested by Sudharaka,You set $u(x,y)= u_{1}(x,y)+u_{2}(x,y)$ and solve separately the two PDE...
$\displaystyle \nabla^2 u_{1} = 0\ ,\ u_{1}(x,0)= f(x)\ ,\ u_{1}(L,y)= 0\ ,\ u_{1}(x,H)= 0\ ,\ u_{1}(0,y)= 0 $
$\displaystyle \nabla^2 u_{2} = 0\ ,\ u_{2}(x,0)= 0\ ,\ u_{2}(L,y)= 0\ ,\ u_{2}(0,y)= 0\ ,\ u_{2}(0,y)= g(y) $ (4)
Other details will be given in a successive post...
Kind regards
$\chi$ $\sigma$
I solved for $u_1$. To solve for $u_2$, I just need to swap x and y and make the substitution $x^* = L - x$.
Is $u_1$ correct and the approach for $u_2$ correct as well?
If we integrate the first boundary condition, we will have $u(x,y) = yf(x) + h(x)$.
Adding in the fact that $y = 0$, tells us that $u(x,0) = h(x)$.
Therefore, we can solve the equation with the following boundary conditions:
u(x,0) = h(x)\quad u(L,y) = 0\quad u(x,H) = 0\quad u(0,y) = g(y).
The general solution for the generic boundary conditions of $u(x,0) = 0, u(L,y) = 0, u(x,H) = f(x),$ and $u(0,y) = 0$ is
\sum_{n = 1}^{\infty}A_n\sin\lambda_n x\sinh\lambda_n y,
where $\lambda_n = \frac{n\pi}{L}$ and
A_n = \frac{2}{L\sinh\lambda_n H}\int_0^Lf(x)\sin\lambda_n xdx.
For the boundary conditions $u(x,0) = h(x), u(L,y) = 0, u(x,H) = 0$, and $u(0,y) = 0$, we need to make the change of coordinates $x = x^*$ and $y^* = H - y$.
Therefore,
u_1(x,y) = \sum_{n = 1}^{\infty}A_n\sin\lambda_n x\sinh[\lambda_n (H - y)]
A_n = \frac{2}{L\sinh\lambda_n H}\int_0^Lh(x)\sin\lambda_n xdx.
Here is the full solution I obtained (Is it correct?):
u(x,y) = \sum_{n=1}^{\infty}\left[A_n\sin\frac{n\pi x}{L}\sinh\left(\frac{n\pi}{L}(H-y)\right) + B_n\sin\frac{n\pi y}{H}\sinh\left(\frac{n\pi}{H}(L-x)\right)\right]
where
A_n = \frac{2}{L\sinh\frac{n\pi H}{L}}\int_0^Lh(x)\sin\frac{n\pi x}{L}dx
and
B_n = \frac{2}{H\sinh\frac{n\pi L}{H}}\int_0^Hg(y)\sin\frac{n\pi y}{H}dy
where
and
My solution is in terms of $h(x)$ not $f(x)$ though. How can I get back $f(x)$?
This is incorrect. You have,
\[u_{y}(x,0)=\left.\frac{\partial}{\partial y}u(x,y)\right|_{y=0}=f(x)\]
You cannot integrate this to obtain, \(u(x,y)\) because there is a substitution \(y=0\). Of course you can write,
\[\int u_{y}(x,0)\,\partial y=\int\left.\frac{\partial}{\partial y}u(x,y)\right|_{y=0}\,\partial y=yf(x)+h(x)\]
but I don't think this will give you any useful information. :)
Ok so what do I do then?
I think you should read >>this<< to understand how to solve a Laplace's equation with three homogeneous boundary conditions. Examples 1 and 2 provides you a complete walk through, so I don't want to write them again here. :)
The problem isn't solving the equation. The problem is the $u_y$ piece.
Please read posts #2 and #5 carefully. There is no need to do anything with the first boundary condition and the problem is equivalent to solving the two equations,
\[\displaystyle \nabla^2 u_{1} = 0\ ,\ u_{1}(x,0)= f(x)\ ,\ u_{1}(L,y)= 0\ ,\ u_{1}(x,H)= 0\ ,\ u_{1}(0,y)= 0\]
and
\[\displaystyle \nabla^2 u_{2} = 0\ ,\ u_{2}(x,0)= 0\ ,\ u_{2}(L,y)= 0\ ,\ u_{2}(0,y)= 0\ ,\ u_{2}(0,y)= g(y)\]
The final solution will be,
and
So it is won't affect the solution to let $u(x,0) = f(x)$ and solve it as the condition $u_y(x,0)=f(x)$ isn't there?
Correct. :)
So I have as my final solution. Correct?
A_n = \frac{2}{L\sinh\frac{n\pi H}{L}}\int_0^Lf(x)\sin\frac{n\pi x}{L}dx.
B_n = \frac{2}{H\sinh\frac{n\pi L}{H}}\int_0^Hg(y)\sin\frac{n\pi y}{H}dy.
u(x,y) = u_1 + u_2 = \sum_{n = 1}^{\infty}\left[A_n\sin\frac{n\pi x}{L}\sinh\left[\frac{n\pi}{L} (H - y)\right] + B_n\sin\frac{n\pi y}{H}\sinh\left[\frac{n\pi}{H}(L - x)\right]\right]
FAQ: Solve Laplace Eqn W/Derivative Boundary Condition
What is the Laplace equation with derivative boundary condition?
The Laplace equation with derivative boundary condition is a partial differential equation that describes the behavior of a scalar field in a region. It is used to model physical phenomena such as heat flow, electric potential, and fluid flow. The derivative boundary condition specifies the behavior of the field at the boundary of the region in terms of its derivatives.
How is the Laplace equation with derivative boundary condition solved?
The Laplace equation with derivative boundary condition is typically solved using various numerical methods such as finite difference, finite element, or boundary element methods. These methods involve discretizing the region into smaller elements and then solving a system of equations to approximate the solution at each element. Advanced techniques such as the Green's function method or separation of variables can also be used in certain cases.
What are the applications of the Laplace equation with derivative boundary condition?
The Laplace equation with derivative boundary condition has a wide range of applications in physics, engineering, and mathematics. It is commonly used to solve problems related to heat transfer, electrostatics, and fluid dynamics. It is also used in computer graphics and image processing for tasks such as image smoothing and inpainting.
What are the boundary conditions for the Laplace equation with derivative boundary condition?
The boundary conditions for the Laplace equation with derivative boundary condition are specified at the boundaries of the region and typically involve the value of the field or its derivatives. These conditions can be of different types, such as Dirichlet, Neumann, or mixed boundary conditions, depending on the problem being solved. The choice of boundary conditions depends on the physical interpretation of the problem and the nature of the boundary.
Can the Laplace equation with derivative boundary condition be solved analytically?
In general, the Laplace equation with derivative boundary condition does not have an explicit analytical solution. However, in certain special cases, such as when the region is a simple geometric shape and the boundary conditions are simple, an analytical solution can be obtained using advanced mathematical techniques such as separation of variables or the method of images. But for most practical problems, numerical methods are used to approximate the solution.
