MHB Solve Limit w/o L'Hôpital: Miras Tussupov's Q on Yaoo Answers
The limit as x approaches infinity for the expression ((3x-1)/(3x-4))^2x can be solved without L'Hôpital's rule by rewriting the fraction as 1 + (3/(3x-4)). This leads to the limit being expressed as (1 + (3/u))^(2/3)(u + 4) after substitution. By applying properties of limits and exponents, the limit can be separated into two parts, one of which evaluates to 1, and the other simplifies to (e^3)^(2/3). Ultimately, the limit is determined to be e^2.
MarkFL
MHB
Here is the question:
Solve limit when x approaches infinity.?
How can I solve limit when x approaches infinity without using L'Hopital's rule?
lim(((3x-1)/(3x-4))^2x)
I have posted a link there to this thread so the OP can view my work.
Mathematics news on Phys.org
Hello Miras Tussupov,
We are given to evaluate:
$$L=\lim_{x\to\infty}\left(\left(\frac{3x-1}{3x-4} \right)^{2x} \right)$$
First, let's rewrite the innermost expression as follows:
$$\frac{3x-1}{3x-4}=\frac{3x-4+3}{3x-4}=1+\frac{3}{3x-4}$$
And now we have:
$$L=\lim_{x\to\infty}\left(\left(1+\frac{3}{3x-4} \right)^{2x} \right)$$
Next, let's use the substitution:
$$x=3x-4$$
to obtain:
$$L=\lim_{u\to\infty}\left(\left(1+\frac{3}{u} \right)^{\frac{2}{3}(u+4)} \right)$$
Applying the properties of exponents, we may write:
$$L=\lim_{u\to\infty}\left(\left(1+\frac{3}{u} \right)^{\frac{8}{3}}\cdot\left(1+\frac{3}{u} \right)^{\frac{2}{3}u} \right)$$
Applying the properties of limits, we may write:
$$L=\lim_{u\to\infty}\left(\left(1+\frac{3}{u} \right)^{\frac{8}{3}} \right)\cdot\lim_{u\to\infty}\left(\left(1+\frac{3}{u} \right)^{\frac{2}{3}u} \right)$$
The first limit is a determinate for and is equal to 1, and the second limit may be rewritten as:
$$L=\left(\lim_{u\to\infty}\left(\left(1+\frac{3}{u} \right)^{u} \right) \right)^{\frac{2}{3}}$$
Using the well-known formula:
$$\lim_{x\to\infty}\left(\left(1+\frac{k}{x} \right)^x \right)=e^k$$
we now have:
$$L=\left(e^3 \right)^{\frac{2}{3}}=e^2$$
Hence, we may conclude:
$$\lim_{x\to\infty}\left(\left(\frac{3x-1}{3x-4} \right)^{2x} \right)=e^2$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
