MHB Solve Linear Inhomogeneous 2nd Order IVP: Joe Smalls' Question
The initial value problem y" + 4y = sin(3t) with conditions y(0) = 1 and y'(0) = 17/5 is solved using the annihilator method. The homogeneous solution is identified as y_h(t) = c_1 cos(2t) + c_2 sin(2t), while the particular solution is found to be y_p(t) = -1/5 sin(3t). By applying the initial conditions, the constants are determined as c_1 = 1 and c_2 = 2. The complete solution to the IVP is y(t) = cos(2t) + 2sin(2t) - (1/5)sin(3t).
MarkFL
MHB
Here is the question:
Solving this initial value problem?
So I'm trying to solve this:
y" + 4y = sin3t
y(0) =1
y'(0) = 17/5
I start by:
(D^2 + 4)(y) = sin3t
(D^2 + 9)(D^2 + 4)(y) = 0
y = C_1(cos3t) + C_2(sin3t) + C_3(cos2t) + C_4(sin2t)
Then I apply initial conditions:
1 = C_1 + C_3
17/5 = 3C_2 + 2C_4
After, I try to solve for a constant by plugging in the particular as y:
(D^2 + 9)(C_1(cos3t)) + C_2(sin3t)) = sin3t
-9C_1(cos3t) - 9C_2(sin3t) + 9C_1(cos3t) + 9C_2(sin3t) = sin3t
sin3t = 0
And that's where I'm stuck. The only thing I can think of is either that I made a mistake, or I can just assume C_1 = 0 because sin3t = 0 to make C_1(cos3t) + C_2(sin3t) = 0 be true. Any tips and help is appreciated!
If you must know, the answer is y = cos2t + 2sin2t - (1/5)(sin3t)
Also, if I can assume C_1 = 0, then I get C_3 = 1. But how do I solve for the other constants?
I have posted a link there to this thread so the OP can view my work.
Mathematics news on Phys.org
Re: Joe Smalls' question at Yahoo! Answers regarding a linear ingomogenous 2nd order IVP
Hello Joe Smalls,
We are given to solve:
$$y"+4y=\sin(3t)$$ where $$y(0)=1,\,y'(0)=\frac{17}{5}$$
You have correctly applied the annihilator method and from this we may conclude that the homogenous solution is:
$$y_h(t)=c_1\cos(2t)+c_2\sin(2t)$$
And the particular solution is of the form:
$$y_p(t)=A\cos(3t)+B\sin(3t)$$
Using the method of undetermined coefficients, we begin by observing that:
$$y_p''(t)=-9y_p(t)$$
And so, by substitution into the ODE, we obtain:
$$-5A\cos(3t)-5B\sin(3t)=0\cdot\cos(3t)+1\cdot\sin(3t)$$
Comparison of coefficients gives us:
$$A=0,\,B=-\frac{1}{5}$$
And so our particular solution is:
$$y_p(t)=-\frac{1}{5}\sin(3t)$$
And thus the general solution by superposition is:
$$y(t)=y_h(t)+y_p(t)=c_1\cos(2t)+c_2\sin(2t)-\frac{1}{5}\sin(3t)$$
Hence:
$$y'(t)=-2c_1\sin(2t)+2c_2\cos(2t)-\frac{3}{5}\cos(3t)$$
Now, using the initial values, we obtain the system:
$$y(0)=c_1=1$$
$$y'(0)=2c_2-\frac{3}{5}=\frac{17}{5}\implies c_2=2$$
And so we find the solution satisfying the given IVP is:
$$y(t)=\cos(2t)+2\sin(2t)-\frac{1}{5}\sin(3t)$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
