MHB Solve Math Problem: Number of Passengers on a Bus
  • Thread starter Thread starter anemone
    Bus
The math problem discusses the number of passengers on a bus before and after two stops. Initially, there were x passengers, with a fraction alighting and others boarding at each stop. After calculations, it was determined that there were 500 passengers on the bus before the first stop. The discussion also mentions the Singapore model method as a potential approach to solving such problems. Additional resources on the Singapore method were shared for those interested in exploring this problem-solving technique further.
anemone
MHB
POTW Director
Hi all, this is another math problem that one can use the Singapore model method to solve. All are welcome to post a solution using the method you would like, if this problem interests you. :)
There were some passengers on a bus. At the first stop, $\dfrac{1}{5}$ of the passengers alighted and 80 boarded the bus. At the second stop, 240 passengers got off and 60 passengers boarded the bus. The bus now had $\dfrac{5}{8}$ of the number of passengers when it left the first stop. How many passengers were on the bus before the first stop?
Mathematics news on Phys.org
Standard algebra:
Let the number passengers initially be x.
Now there are $x- \dfrac{1}{5}x+ 80= \dfrac{4}{5}x+ 80$ passengers on the bus.
Now there are $\dfrac{4}{5}x+ 80- 240+ 60= \dfrac{4}{5}x- 100$ passengers on the bus.
So $\dfrac{4}{5}x- 100= \dfrac{5}{8}\left(\dfrac{4}{5}x+ 80\right)= \dfrac{1}{2}x+ 50$.
Solve the equation $\dfrac{4}{5}x- 100= \dfrac{1}{2}x+ 50$ for x.
Subtract $\dfrac{1}{2}x$ from both sides- $\dfrac{4}{5}- \dfrac{1}{2}= \dfrac{8}{10}- \dfrac{5}{10}= \dfrac{3}{10}$.
$\dfrac{3}{10}x- 100= 50$.
Add 100 to both sides. $\dfrac{3}{10}x= 150$.
Multiply both sides by $\dfrac{10}{3}$.
$x= 500$.
There were originally 500 passengers on the bus.
(That's a large bus!)
Check:
(When I first did this problem, I made a trivial arithmetic mistake. Always check!)
$\dfrac{1}{5}$ of 500 is 100. 100 of the 500 passengers got off, leaving 500- 100= 400 passengers and another 80 boarded so there are now 480 passengers on the bus.
480- 240= 240. 240+ 60= 300.
The bus now had $\frac{5}{8}$ of the number of passengers when it left the first stop.
When it left the first stop it had 480 passengers. $\frac{5}{8}$ of that is 5(60)= 300. Yes, that is what we got.
Before the first stop the bus had 500 passengers,
Now, how would the "Singapore model method" solve this problem?
My Attempt
After if left the 1st stop $\dfrac{5}{8}$ remained so $\dfrac{3}{8}$ was the number of more persons alighted than boarded
The number is 180
so $\dfrac{3}{8}$ of number of persons when it left the $1^{st}$ stop is 180
so number of persons when it left $1^{st}$ stop =$\dfrac{180}{{\frac{3}{8}}} = 480$
That was the number after 80 boarded
So the number before 80 boarded was 480-80 = 400
after $\dfrac{1}{5}$ got of remaining was $\dfrac{4}{5}$ which is 400
so number started with $\dfrac{400}{{\frac{4}{5}}} = 500$
[TIKZ]
\filldraw [fill=yellow,thick] foreach \i in {-4,...,-1} { ({\i*2.4},0) rectangle ({(\i+2)*2.4},1) };
\filldraw [fill=green, thick, dotted] foreach \i in {3,...,9} { ({\i*0.8},0) rectangle ({(\i+2)*0.8},1) };
\node at (-8.5,1.4) {\small 1 unit = 2 parts};
\draw [<->] (-9.5, 1.2) -- (-7.2, 1.2);
\node at (-8.4,0.6) {\tiny alighted passengers};
\node at (-8.4,0.2) {\tiny at 1st stop};
\draw[thick, dotted] (-7.2, 1) -- (-9.5, 0);
\draw[thick, dotted] (-7.8, 1) -- (-9.6, 0.2);
\draw[thick, dotted] (-8.4, 1) -- (-9.65, 0.4);
\draw[thick, dotted] (-7.2, 0.7) -- (-9, 0);
\draw[thick, dotted] (-7.2, 0.4) -- (-8.2, 0);
\draw [<->] (-7.2, 1.2) -- (-6, 1.2);
\node at (-6.6,1.4) {\small 1 part};
\draw [<->] (-7.2, 2) -- (8.8, 2);
\node at (0,2.2) {\small Total passengers on the bus after 1st stop and before 2nd stop};
\draw [<->] (-1.2, 1.2) -- (4.8, 1.2);
\node at (2,1.5) {\small Number of passengers got off the bus at 2nd stop = 240 - 60 = 180};
\draw[thick, dotted] (4.8, 0.2) -- (3.6, 0);
\draw[thick, dotted] (4.8, 0.4) -- (2.4, 0);
\draw[thick, dotted] (4.8, 0.6) -- (1.2, 0);
\draw[thick, dotted] (4.8, 0.8) -- (-0, 0);
\draw[thick, dotted] (4.8, 1) -- (-1.2, 0);
\draw[thick, dotted] (3.6, 1) -- (-1.2, 0.2);
\draw[thick, dotted] (2.4, 1) -- (-1.2, 0.4);
\draw[thick, dotted] (1.2, 1) -- (-1.2, 0.6);
\draw[thick, dotted] (0, 1) -- (-1.2, 0.8);
\draw[thick, dotted] (-6,0) -- (-6,1);
\draw[thick, dotted] (-3.6,0) -- (-3.6,1);
\draw[thick, dotted] (-1.2,0) -- (-1.2,1);
\draw[thick, dotted] (1.2,0) -- (1.2,1);
\node at (2.8,0.5) {\small 10};
\node at (3.6,0.5) {\small 10};
\node at (4.4,0.5) {\small 10};
\node at (5.2,0.5) {\small 10};
\node at (6,0.5) {\small 10};
\node at (6.8,0.5) {\small 10};
\node at (7.6,0.5) {\small 10};
\node at (8.4,0.5) {\small 10};
[/TIKZ]
Represent the given information in the model diagram above, the question wanted us to find the value for 10 parts.
From the model diagram,
$\begin{align*}3 \text{ parts} + 30 &=180\\3 \text{ parts}&=150\\ 1\text{ part}&=50 \\ \therefore 10\text{ parts}&=500\end{align*}$
Hi anemone,
Is there information available somewhere about the Singapore method ?
Hi castor28!
Thanks for showing your interest in Singapore model method in solving primary math word problems.
I just found a few insightful articles that discuss about the effectiveness to use model method to solve word problems, I hope you or anyone who are interested (@Fantini) find those articles meaningful to you!
https://bsrlm.org.uk/wp-content/uploads/2016/02/BSRLM-IP-35-3-20.pdf
http://people.math.harvard.edu/~engelwar/MathS305/Singapore Model Method Text.pdf
https://files.eric.ed.gov/fulltext/EJ1115069.pdf
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
