MHB Solve Maths Sequences & Series - Get Passing Grade Now
ertagon2
Can someone help me with these. These are the last 5 questions that I have to do and if I get them right I pass maths.
Do you mean to say you can't do 2 and 4?? What are the possible values for n? Do you know what an nth partial sum is?
Hint: 3 is a geometric ratio. What is the sum for this?
-Dan
If, as you appear to be saying, you know nothing at all about these problems, why should you pass maths?
The second problem asks you to find [math]\sum_{n=0}^4 (n-1)^2[/math]. Do you know what that means? If you do then this is a simple arithmetic problem. If you do not then you should Not pass maths!
A sphere as topological manifold can be defined by gluing together the boundary of two disk. Basically one starts assigning each disk the subspace topology from ##\mathbb R^2## and then taking the quotient topology obtained by gluing their boundaries. Starting from the above definition of 2-sphere as topological manifold, shows that it is homeomorphic to the "embedded" sphere understood as subset of ##\mathbb R^3## in the subspace topology.
