Solve Polar Coordinates: (-2*sqrt3) – (2*i) = 4*e^(i*7*pi/6)
In summary, the given equation can be rewritten as 4*e^(i*7*pi/6) using Convention I, where the angle theta is measured from 0 to 2*pi. However, using Convention II where the angle goes from (-)*pi to (+)*pi, the angle would be measured as (-)*pi/6 and the resulting equation would not be the same as the given equation. It is important to note the direction of rotation and the starting point when measuring angles in order to accurately perform calculations.
hugo28
Question: Given (-2*sqrt3) – ( 2*i) = 4*e^(i*7*pi/6)
Perform the following:
(a) Convention I: angle go from (0) to 2*pi.
(b) Convention II: angle goes from (-)*pi to (+)*pi.
Part (a): Convention I: angle go from (0) to 2*pi.
r = (x^2 + y^2)^1/2 = sqrt16 = 4
(theta) = tan^(-1) |y/x =1/sqrt3| = pi/6
Since x = (-) and y = (-) it is in the third quadrant
(theta) = pi + pi/6 = 7*pi/6
Thus, z = r*e^(i*(theta)) = 4*e^(i*7*pi/6)
Part (b): Convention II: an angle goes from (-)*pi to (+)*pi.
Given convention II starts at (-)*pi to (+)*pi,
Thus, the angle = pi/6 in the third quadrant becomes (-)*pi/6
Therefore: z = r*e^(i*(theta)) = 4*e^(i*7*pi/6) or
= 4*[cos(- pi/6) + i*sin(- pi/6)]
= 4*[sqrt3/2 – ½*i ]
= (2*sqrt3) – (2*i)
Result: is NOT the same as given (-2*sqrt3) – (2*i)
The convention II: an angle goes from (-)*pi to (+)*pi, that gives me most trouble.
At all possible would you please guide me through this (b)’s part and elucidate convention II, also. Sincerely.
Note: From my understanding and also can be wrong too that: from left hand side
at (-1)*pi rotates downward and toward right hand side to zero. From zero rotates upward and toward left hand side, is 0 to (+)*pi (counterclockwise direction).
Clockwise direction, from 0 to (-)*pi (like 3 to 9) is for z* (complex conjugate) only. Thanks.
The convention is to measure angles from the +x axis, taking the counterclockwise direction to be the positive direction. So the angle [itex]-\pi/6[/itex] would actually be in the fourth quadrant, not the third. That's where you went wrong in part (b).
FAQ: Solve Polar Coordinates: (-2*sqrt3) – (2*i) = 4*e^(i*7*pi/6)
What are polar coordinates?
Polar coordinates are a system of coordinates used to locate a point in a two-dimensional space. It uses a distance from the origin (r) and an angle (θ) to describe the location of a point.
How do you convert from rectangular coordinates to polar coordinates?
To convert from rectangular coordinates (x,y) to polar coordinates (r,θ), you can use the following formulas:
r = √(x^2 + y^2) and θ = tan^-1 (y/x)
How do you solve equations with polar coordinates?
To solve an equation with polar coordinates, you can substitute the given values of r and θ into the equation and simplify. In this example, we can substitute r = 2√3 and θ = 7π/6 into the equation (-2√3) – (2i) = 4e^(i*7π/6) to solve for the unknown variable.
What is the significance of e in polar coordinates?
e is the base of the natural logarithm and is often used in polar coordinates to represent a complex number. In this equation, 4e^(i*7π/6) represents a point on the complex plane with a distance of 4 and an angle of 7π/6, where e is being raised to the power of the imaginary unit (i) multiplied by the angle.
How do you graph polar coordinates?
To graph polar coordinates, you can plot the point on a polar coordinate grid using the given values of r and θ. The distance r represents the distance from the origin, and the angle θ represents the direction of the point from the positive x-axis.
