Solve Polynomial Equation z^6-2z^3+2=0
  • MHB
  • Thread starter Petrus
  • Tags
    Polynomial
In summary, the conversation discussed finding all the roots to the polynomial z^6-2z^3+2=0. It was suggested to substitute z^3=t and then use polar form to find the roots. The conversation also discussed using Euler's formula and de Moivre's theorem to find all six roots. Finally, the correct solutions were found by evenly spacing the solutions around a circle and using the same magnitude for each solution.
Petrus
702
Hello MHB,
Find all roots to \(\displaystyle z^6-2z^3+2=0\)
I can se we there will be 6 roots.
I start with subsitute \(\displaystyle z^3=t\) so we got
\(\displaystyle t^2-2t+2=0\) and we get \(\displaystyle t_1=1+i\) and \(\displaystyle t_2=1-i\)
what shall I do next? Shall I go to polar form?
Regards,
Mathematics news on Phys.org
Yes, that would be a good way to continue and find your six roots.
in that t I get \(\displaystyle \sqrt{2}e^{i \frac{\pi}{4}}\) so I shall solve \(\displaystyle t^3=\sqrt{2}e^{i \frac{\pi}{4}}\)
Yes, in fact you could use:
\(\displaystyle t^3=\sqrt{2}e^{\pm\frac{\pi}{4}i}\)
to get all six roots.
I still don't get six roots, I get \(\displaystyle 2^{1/6}e^{\pm\frac{\pi}{12}i}\) but that is not six roots.
If it were me, I would use Euler's formula to express $t^3$ in trigonometric form, then use de Moivre's theorem to get all six roots.
Or equivalently write:
\(\displaystyle t^3=\sqrt{2}e^{\pm\left(\frac{\pi}{4}+2k\pi \right)i}\)
Then let \(\displaystyle k\in\{-1,0,1\}\) to get \(\displaystyle \theta\in[-\pi,\pi]\)
Is this correct?
\(\displaystyle 2^{1/6}e^{\pm\frac{\pi}{12}+ \frac{k2\pi}{12}}\) \(\displaystyle k=0,1,2,3,4,5\)
Petrus said:
Is this correct?
No, you have omitted $i$ from the exponent, and you want to get 3 roots from both values of $t^3$ not 6 roots from one value.
Please note I have added to my previous post on how to do this.
Hello Mark,
I don't understand that one cause I can't find it on my book. The only one I could find is de moivres sats so we can write \(\displaystyle t=2^{1/6}e^{\pm( \frac{\pi}{12}+ \frac{k2\pi}{12})i}\) \(\displaystyle k=0,1,2,3,4,5\), I am pretty much clueless right now...
Regards,
I start to understand what you do but now where you get your k and \(\displaystyle \theta\)
Petrus said:
Hello MHB,
Regards,
It's always easiest to remember that there are as many solutions (at least in one rotation of a circle) to any complex polynomial as the degree of the polynomial, and they are all evenly spaced around a circle, so they all have the same magnitude and are separated by the same angle. So your sixth-degree polynomial has six solutions, and you have reduced it down to two cubics, each which will have three solutions.
For your first cubic, you have
\(\displaystyle \displaystyle \begin{align*} z^3 &= 1 + i \\ z^3 &= \sqrt{2}\,e^{\frac{\pi}{4}\,i} \\ z &= \left( \sqrt{2} \, e^{\frac{\pi}{4}\,i} \right) ^{\frac{1}{3}} \\ z &= \sqrt[6]{2} \, e^{\frac{\pi}{12}\,i} \end{align*}\)
And now remembering that all three solutions have the same magnitude and are evenly spaced about a circle, they will be separated by an angle of \(\displaystyle \displaystyle \begin{align*} \frac{2\pi}{3} \end{align*}\), and so the solutions are
\(\displaystyle \displaystyle \begin{align*} z_1 &= \sqrt[6]{2} \, e^{\frac{\pi}{12}\,i} \\ \\ z_2 &= \sqrt[6]{2}\, e^{\frac{3\pi}{4}\,i} \\ \\ z_3 &= \sqrt[6]{2}\, e^{-\frac{7\pi}{12}\,i} \end{align*}\)Follow a similar process to find the solutions to \(\displaystyle \displaystyle \begin{align*} z^3 = 1 - i \end{align*}\) :)
Hello,
Now I do understand and get correct answer as facit!:) Thanks MarkFL and prove it for taking your time!
Regards,
FAQ: Solve Polynomial Equation z^6-2z^3+2=0
What is a polynomial equation?
A polynomial equation is an algebraic equation that contains one or more terms with variables raised to positive integer exponents. It can have constants, variables, and coefficients, and the degree of a polynomial is the highest exponent in the equation.
How do I solve a polynomial equation?
To solve a polynomial equation, you can use several methods such as factoring, the quadratic formula, or the rational roots test. In this case, the polynomial z^6-2z^3+2=0 can be factored as (z^3-1)(z^3-2)=0 and solved by setting each factor equal to zero and solving for z.
What is the degree of the polynomial equation z^6-2z^3+2=0?
The degree of a polynomial equation is the highest exponent in the equation. In this case, the degree is 6 because the highest exponent is 6.
Can the polynomial equation z^6-2z^3+2=0 have complex solutions?
Yes, the polynomial equation can have complex solutions. In this case, the solutions are z=1, z=-1, and z=2, which can be written as z=1, z=1i, z=-1, z=-1i, z=2, and z=2i, where i is the imaginary unit.
Is there a general formula for solving polynomial equations?
Yes, there is a general formula for solving polynomial equations called the fundamental theorem of algebra. It states that a polynomial equation of degree n has n complex solutions. However, for higher degree polynomials, finding exact solutions can be difficult, and numerical methods may be used instead.
