Solve Primal Dual Problems: Understand Convex Function & Lagrangian
  • MHB
  • Thread starter OhMyMarkov
  • Tags
    Dual
In summary, the minimization problem with a constraint and its dual problem, obtained by adding a Lagrange multiplier term, are two different approaches to solving an optimization problem. The dual problem involves maximizing over Lagrange multipliers, while the original problem involves minimizing over decision variables. This can result in a duality gap, or difference between the optimal values of the two problems, for general convex functions. However, for linear programs and second order cone programs, the duality gap is zero due to special properties of these types of problems.
OhMyMarkov
83
Hello everyone!
I got this topic confusing me:
Suppose we would like minimize a convex function such that a given constraint is satisfied, mathematically, we would solve:
$arg min _x f(x)$ such that $c(x) \in S$ where $c(x)$ is the constraint function and $S$ is the allowable set of values $c(x)$ can have (I don't know if this is correct in mathematical notation...)
The dual of this problem would be solving the Lagrangian, that is: $arg min _x f(x) + \lambda c(x)$ where $\lambda > 0$. But they say that the two problems are not equivelent in a sense that there is what is called a duality gap between the two results, but that this gap is zero for linear programs and second order cone programs. What I want ask is that, how are the two problems different and why do they yield different results, we've been using Lagrange multipliers for a while and it is shocking that the result it produces may not be correct.Any help is appreciated!
Mathematics news on Phys.org
Hello there,
Thank you for bringing up this interesting topic. I am a scientist who specializes in optimization and I would be happy to provide some clarification on the differences between the two problems and why they yield different results.
Firstly, you are correct in your mathematical notation for the minimization problem with a constraint. The constraint function, $c(x)$, represents a set of conditions that the solution, $x$, must satisfy. The allowable set of values for $c(x)$, denoted by $S$, is often referred to as the feasible region.
Now, let's talk about the dual problem. The Lagrangian, which is obtained by adding the product of the constraint function and a Lagrange multiplier, is a way to convert the constrained optimization problem into an unconstrained one. The dual problem is essentially finding the minimum of this unconstrained function, which is equivalent to finding the maximum of the original function subject to the constraint.
The reason why the two problems may yield different results is because the dual problem involves maximizing over the Lagrange multipliers, while the original problem involves minimizing over the decision variables. In some cases, the optimal solutions for the two problems may not be the same, resulting in a duality gap. This gap can be thought of as the difference between the optimal values of the two problems.
As you mentioned, for linear programs and second order cone programs, the duality gap is zero. This is because these types of problems have special properties that allow the optimal solutions for the two problems to be equal. However, for more general convex functions, the duality gap may not be zero and the two problems may yield different results.
I hope this helps to clarify the differences between the two problems and why they may yield different results. If you have any further questions, please don't hesitate to ask. Good luck with your research!
FAQ: Solve Primal Dual Problems: Understand Convex Function & Lagrangian
What are primal and dual problems in convex optimization?
Primal and dual problems refer to two different formulations of the same optimization problem. In convex optimization, the primal problem is the original problem that seeks to minimize a convex objective function subject to convex constraints. The dual problem is a related problem that seeks to maximize a convex function subject to convex constraints, and it provides a lower bound on the optimal value of the primal problem.
What is a convex function?
A convex function is a function whose graph is always "curved up" or "bowed" in a certain way. More precisely, a function is convex if all the points on the line segment connecting any two points on the graph lie above or on the graph. In other words, it is a function where the slope is always increasing or constant, never decreasing.
What is the Lagrangian in convex optimization?
The Lagrangian, also known as the Lagrangian dual function, is a mathematical function used in convex optimization to formulate the dual problem. It is defined as the infimum (greatest lower bound) of all the Lagrange multipliers that satisfy the convex constraints of the primal problem. The Lagrangian helps us to solve problems that are difficult to tackle directly by transforming them into easier, equivalent problems.
What is the importance of solving primal-dual problems in convex optimization?
Solving primal-dual problems in convex optimization is important because it allows us to find the optimal solution to an optimization problem by first solving a different but related problem. This approach often simplifies the problem and leads to more efficient and effective solutions. Additionally, the duality theory in convex optimization provides valuable insights into the problem structure and can help us understand the trade-offs between different solutions.
What are some applications of solving primal-dual problems in convex optimization?
The applications of solving primal-dual problems in convex optimization are extensive and diverse. Some common examples include resource allocation problems, portfolio optimization, and machine learning algorithms. Primal-dual methods are also widely used in engineering and economics for solving complex optimization problems in areas such as transportation, energy management, and supply chain optimization.
