MHB Solve Probability Problem: An Urn with 5 Black & 4 White Balls
  • Thread starter Thread starter Yankel
    Balls
The discussion revolves around calculating the probability of drawing a white ball first, given that the last ball drawn is white, from an urn containing 5 black and 4 white balls. Participants explore the possible outcomes of the drawing process, noting that the experiment concludes when two balls of the same color are drawn consecutively. There is confusion regarding the total number of balls used in probability calculations, with some suggesting the denominator should be 9 instead of 11. Various interpretations of the problem lead to different calculations, with one participant arriving at a probability of 12/17. The complexity of conditional probability in this scenario is a key focus, highlighting the need for clarity in understanding the problem's structure.
Yankel
An urn has 5 black balls ans 4 white balls in it. We randomly choose a ball, and return it to the urn, until we get 2 balls with the same colour. What is the probability that the first ball was white, if we know that the last one was white ? I tried building a tree, and realized that the experiment can have 2 or 3 stages, not more. The answer say 65/81, which makes no sense to me, I think it's a mistake. Can you please help me solve this problem ? I used conditional probability, with no luck.
Thanks !
Mathematics news on Phys.org
Thanks !
Hey Yankel! ;)
Possible outcomes that end with a white ball, are:
\begin{array}{|c|c|}
\hline
\text{Outcome} & \text{Unconditional Probability} \\
\hline
WW & \frac 4{11} \cdot \frac 3{10} \\
B\,WW & \frac 5{11} \cdot \frac4{10} \cdot \frac 3{9} \\
WB\,WW & ...\\
B\,WB\,WW \\
WB\,WB\,WW \\
B\,WB\,WB\,WW \\
\hline
\end{array}
And we're looking for:
$$P(\text{first white} \mid \text{last white}) = \frac{P(\text{first white} \wedge\text{last white})}{P(\text{last white})}$$
(Thinking)
I did not understand the experiment to end when there are two balls of the same color in a row...
This is an interesting interpretation, maybe this is my mistake. I though you could not get more than 2 W overall.
And why dividing by 11 ? There are 9 balls.
Hmm... your interpretation could well be right as well... (Thinking)
In that case, we would only have WW, WBW, and BWW.
Still, if I calculate that, I'm getting $P(\text{first white} \mid \text{last white}) = \frac {12}{17}$.
And you are quite right, the division should be by 9 instead of by 11.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
