Solve Quartic Polynomial: Find Coefficients & Values of q - Yahoo! Answers
In summary, we are given the function P(x) = x^4 + ax^3 + bx^2 + cx + d and are tasked with finding the values of the variables that satisfy the given guidelines. By analyzing the given information, we find that a and c must be equal to 0, b must be -4, and d must be 1. Additionally, the possible values for q are ±√2.
MarkFL
MHB
13,288
Here is the question:
Let P(x) = x4 + ax3 + bx2 + cx + d. Need to find the values of the variable that satisfy the guidelines below?
Let P(x) = x4 + ax3 + bx2 + cx + d. The graph of y = P(x) is symmetric with respect to the y-axis, has a relative MINIMUM at (0, 1) and has an absolute minimum at (q, -3). Determine the values of a,b,c and d, using these values write an expression for p(x). Also, find all possible values of q.
Here is a link to the question:
Let P(x) = x4 + ax3 + bx2 + cx + d. Need to find the values of the variable that satisfy the guidelines below? - Yahoo! Answers
I have posted a link there to this topic so the OP can find my response.
Mathematics news on Phys.org
Hello tin h,
We are given:
\(\displaystyle P(x)=x^4+ax^3+bx^2+c^x+d\)
If $P(x)$ is symmetric with respect to the $y$-axis, then this means $P(x)$ is even, i.e., $P(-x)=P(x)$, and so this means $a=c=0$, leaving us with:
\(\displaystyle P(x)=x^4+bx^2+d\)
The fact that $P(x)$ has a relative minimum at $(0,1)$ tells us:
\(\displaystyle P(0)=d=1\)
\(\displaystyle P'(x)=4x^3+2bx\)
The fact that \(\displaystyle P'(0)=0\) yields no additional information.
\(\displaystyle P''(x)=12x^2+2b\)
We know by the second derivative test we must have:
\(\displaystyle P''(0)>0\,\therefore\,0<b\).
The fact that $P(x)$ has an absolute minimum at $(q,-3)$ tells us:
\(\displaystyle P(q)=q^4+bq^2+1=-3\,\therefore\,q^4+bq^2=-4\)
\(\displaystyle P'(q)=4q^3+2bq=0\,\therefore\,2q^3+bq=0\)
Solving both equations for $b$ and equating, we find:
\(\displaystyle b=-\frac{q^4+4}{q^2}=-2q^2\)
\(\displaystyle q^4+4=2q^4\)
\(\displaystyle q^4=4\)
and since $q$ is real, we find:
\(\displaystyle q=\pm\sqrt{2}\)
and so substituting into the first equation we used, we find:
\(\displaystyle b=-4\)
\(\displaystyle P''(q)=12q^2+2b\)
\(\displaystyle P''(0)>0\,\therefore\,0<6q^2+b\).
We see that the values we found for $b$ and $q$ satisfy this requirement.
However, we find that the extremum at (0,1) must be intended to be a local maximum, not a minimum.
In conclusion, we have found:
\(\displaystyle a=0,\,b=-4,\,c=0,\,d=1,\,q=\pm\sqrt{2}\)
To tin h and any other guests viewing this topic, I invite and encourage you to register and post other calculus problems in our http://www.mathhelpboards.com/f10/ forum.
Best Regards,
Mark.
Related to Solve Quartic Polynomial: Find Coefficients & Values of q - Yahoo! Answers
What is a quartic polynomial?
A quartic polynomial is a mathematical expression that contains terms with a variable raised to the fourth power (e.g. x^4) and coefficients that determine the values of these terms.
How do you solve a quartic polynomial?
To solve a quartic polynomial, you can use various methods such as factoring, completing the square, or using the quadratic formula. You can also use numerical methods, such as the Newton-Raphson method, to approximate the solutions.
What are coefficients in a quartic polynomial?
Coefficients in a quartic polynomial are the numbers that are multiplied by the variable terms. They determine the degree and shape of the polynomial.
How do you find the coefficients of a quartic polynomial?
The coefficients of a quartic polynomial can be found by looking at the terms in the polynomial expression. For example, in the polynomial 2x^4 + 3x^3 + 7x^2 + 5x + 9, the coefficients are 2, 3, 7, 5, and 9.
What values can q take in a quartic polynomial?
Q can take on any real number value in a quartic polynomial. However, if the polynomial is restricted to only have real solutions, the values of q may be limited to certain ranges or sets of numbers.
