Solve Radical Equation: 5x√2x-3=4
  • MHB
  • Thread starter blackfriars
  • Tags
    Radical
In summary: I'm sorry, but you are not going to be able to solve this problem using synthetic division. The equation has no rational roots, so it cannot be solved using standard methods.
blackfriars
solving this problem
not sure how to calculate this 5x√2x-3=4
i was planning to isolate radical by subtracting the 5x when i do this i end with a quadratic and no solutions
any help appreciated
Mathematics news on Phys.org
I am going to assume the equation is:
\(\displaystyle 5x\sqrt{2x-3}=4\)
Now, if we square both sides, we get:
\(\displaystyle 25x^2(2x-3)=16\)
In standard form, this is:
\(\displaystyle 50x^3-75x^2-16=0\)
Discarding the extraneous complex roots, we are left with:
\(\displaystyle x=\frac{1}{10}\left(5+\sqrt[3]{5\left(57-8\sqrt{41}\right)}+\sqrt[3]{5\left(57+8\sqrt{41}\right)}\right)\approx1.62168011109094\)
I used W|A to get the exact value of the root, which could be found using a cubic root formula, however, in practice I would use a numeric technique to approximate the root to a desired level of accuracy. :D
hi what is w/a and i was trying to use synthetic division , i do not understand your solution , sorry if it sounds dumb
Did I interpret the problem correctly?
W|A is:
Wolfram Alpha
Synthetic/polynomial division isn't going to work here, because there are no rational roots. We have one irrational real root, and 2 extraneous complex roots.
Please don't feel dumb for asking questions if you don't understand something...it is only "dumb" to not understand something offered as help and not ask about it. :D
hi thanks, you did interpret the problem correctly
the solution you have given has me confused
i don't know how to go from the cubic equation to your solution
could you possibly show me the steps or guide me to an explanation this is the first time i have come across radical equations
thanks
thanks
Well, you would have to look up methods for solving general cubic equations. These are in general very messy and cumbersome formulas (unlike the quadratic formula), and is why I would use a numeric technique instead.
Are you sure you copied the question correctly? This is a bad problem to present to students who have not been given general methods to solve cubics, or who have not studied numeric root finding techniques.
hi, yes the question is correct as it was given to use on a paper
we were shown how to do synthetic division when we were given the factor or the root, as this equation did not have a singular x term i wrote it as 50x^3-75x^2+0x-16=0
i tried to list all the factors of -16 and 50 it was a long process
i did not find grouping to work to find the factors
the solution you gave me i do not know how to get from the cubic to it
hope you understand my confusion thanks
As I explained, I used W|A to obtain the exact value of the root, however, here is a page explaining the "Cubic Formula" derivation:
Cubic Formula
As you can see it is quite the ordeal, and is why I would use a numeric technique, like the Newton-Raphson method instead. :D
hi Markf, well i have just used the Newton method, it was long, but the result i got was similar to yours
this is what i did i inputed 1.6216 as the x value in this eq 50x^3-75x^2-16=15.98... this is fine
but when i input the same value into the original eq i get something different 5(1.6216)+Sqroot2x-3=4 ido not get 4 but i get 8.6...
could you tell me the reason or is this the way it is meant to be
thanks
thanks
The original equation is:
You are using instead:
\(\displaystyle 5x+\sqrt{2x-3}=4\)
hi mark , really sorry , but i made the mistake the original equation was 5x+ sqroot2x-3=4
i did not cop the missing addition sign
sorry about that
sorry about that
In that case, I wold isolate the radical:
\(\displaystyle \sqrt{2x-3}=4-5x\)
Square both sides:
\(\displaystyle 2x-3=16-40x+25x^2\)
Write in standard form:
\(\displaystyle 25x^2-42x+19=0\)
We find the discriminat to be negative, which means the two complex roots are extraneous, and therefore there is no solution to the original equation.
hi, yes this is what i initially did and when entering the data into my casio i kept getting an error message
this led me to believe there was no solution, but then again i was not 100% sure
thanks so much for your help
FAQ: Solve Radical Equation: 5x√2x-3=4
How do you solve a radical equation?
To solve a radical equation, you must isolate the radical term on one side of the equation and then square both sides of the equation to eliminate the radical.
What is the first step in solving a radical equation?
The first step in solving a radical equation is to isolate the radical term by moving any other terms to the other side of the equation.
How do you square both sides of an equation?
To square both sides of an equation, you must square each term on both sides of the equation using the exponent rule: (a + b)^2 = a^2 + 2ab + b^2.
What do you do after squaring both sides of an equation?
After squaring both sides of an equation, you should continue to simplify the equation by combining like terms and solving for the variable.
Can a radical equation have more than one solution?
Yes, a radical equation can have more than one solution. In fact, it can have up to n solutions, where n is the index of the radical. This means a square root equation can have 2 solutions, a cube root equation can have 3 solutions, and so on.
