MHB Solve Real Solutions of $(1-x_1)^2+\cdots+x_{2013}^2=\frac{1}{2014}$
  • Thread starter Thread starter magneto1
The equation presented involves finding real solutions to a specific sum of squared differences equating to a fraction. By defining variables and applying the Cauchy–Schwarz inequality, it is shown that all differences between consecutive terms must be equal, leading to a unique solution of the form \(x_i = 1 - \frac{i}{2014}\) for \(1 \leq i \leq 2013\). However, it is noted that there exists another set of solutions that also satisfies the equation, indicating that the problem may have multiple valid solutions. Further exploration is needed to identify these additional solutions. The discussion highlights the complexity of the equation and the necessity for a comprehensive solution set.
magneto1
Find all the solutions in real numbers to the equation:
(1-x_1)^2 +(x_1-x_2)^2+(x_2-x_3)^2 + \cdots + (x_{2012}-x_{2013})^2 + x_{2013}^2 = \frac{1}{2014},
and show that you have all of the solutions that would satisfy the equation.
Mathematics news on Phys.org
[sp]and show that you have all of the solutions that would satisfy the equation.[/QUOTE]
Let $x_0 = 1$, $x_{2014} = 0$ and $y_i = x_{i-1} - x_i\ (1\leqslant i\leqslant 2014)$. Then $\sum y_i = x_0 - x_{2014} = 1-0 = 1$ (telescoping sum), and $\sum y_i^2 = \frac1{2014}.$ Let $z_i = 1\ (1\leqslant i\leqslant 2014)$. Then $1 = \sum y_i = \Bigl(\sum y_i\Bigr)^2 = \Bigl(\sum y_iz_i\Bigr)^2 \leqslant \sum y_i^2 \sum z_i^2 = \frac{2014}{2014} = 1$ (Cauchy–Schwarz). But equality holds in the Cauchy–Schwarz inequality only if $y_i = cz_i$ for some constant $c$. Thus all the $y_i$ are equal, and since their sum is $1$ they must all be equal to $\dfrac1{2014}.$ Therefore $x_i = 1 - \dfrac i{2014}\ (1\leqslant i\leqslant 2013)$, and that is the unique solution.[/sp]
Let $x_0 = 1$, $x_{2014} = 0$ and $y_i = x_{i-1} - x_i\ (1\leqslant i\leqslant 2014)$. Then $\sum y_i = x_0 - x_{2014} = 1-0 = 1$ (telescoping sum), and $\sum y_i^2 = \frac1{2014}.$ Let $z_i = 1\ (1\leqslant i\leqslant 2014)$. Then $1 = \sum y_i = \Bigl(\sum y_i\Bigr)^2 = \Bigl(\sum y_iz_i\Bigr)^2 \leqslant \sum y_i^2 \sum z_i^2 = \frac{2014}{2014} = 1$ (Cauchy–Schwarz). But equality holds in the Cauchy–Schwarz inequality only if $y_i = cz_i$ for some constant $c$. Thus all the $y_i$ are equal, and since their sum is $1$ they must all be equal to $\dfrac1{2014}.$ Therefore $x_i = 1 - \dfrac i{2014}\ (1\leqslant i\leqslant 2013)$, and that is the unique solution.[/sp][/QUOTE]
Almost correct. There is actually another set of $x_i$ that would work.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
  • · Replies 25 ·
  • · Replies 21 ·
