Solve Root of Equation Q1a: Help Here
  • MHB
  • Thread starter wonguyen1995
  • Tags
    Root
In summary, Ackbach asked if the question posted was a question that would receive marks, and if it was from a graded assignment or an exam. If it was from a practice test, there was no issue, but if it was from a graded test, the thread would need to be closed.
wonguyen1995
Can you help me question 1a?
Mathematics news on Phys.org
$$c(x)=10-20(e^{-\frac{x}{5}}-e^{-\frac{3x}{4}})$$
To find the critical points we have to find the points $x$ such that $c'(x)=0$:
$$c'(x)=20\left ( e^{-\frac{x}{5}}\left ( -\frac{1}{5} \right )-e^{-\frac{3x}{4}}\left ( -\frac{3}{4} \right ) \right )=-4e^{-\frac{x}{5}}+15e^{-\frac{3x}{4}} $$
$$c'(x)=0 \Rightarrow -4e^{-\frac{x}{5}}+15e^{-\frac{3x}{4}}=0 \Rightarrow 4e^{-\frac{x}{5}}=15e^{-\frac{3x}{4}} \\ \Rightarrow \ln \left ( 4e^{-\frac{x}{5}} \right ) =\ln \left ( 15e^{-\frac{3x}{4}} \right ) \Rightarrow \ln 4+ \ln e^{-\frac{x}{5}} =\ln 15+\ln e^{-\frac{3x}{4}} \\ \Rightarrow \ln 4 -\frac{x}{5} =\ln 15-\frac{3x}{4} \Rightarrow \frac{3x}{4}-\frac{x}{5} =\ln 15-\ln 4 \\ \Rightarrow \frac{15x}{20}-\frac{4x}{20} =\ln \frac{15}{4} \Rightarrow \frac{11x}{20} =\ln \frac{15}{4} \\ \Rightarrow x =\frac{20}{11}\ln \frac{15}{4}$$
To show that at this point the function achieves its minimum we have to calculate the second derivative of the function at this point, $c''\left ( \frac{20}{11}\ln \frac{15}{4}\right )$, and it should be $>0$.
Is this question part of an exam for credit?
what do you mean?
wonguyen1995 said:
what do you mean?
Hi wonguyen1995,
What Ackbach meant was whether the question you posted is a question that you will get marks for. Whether it's part of a graded assignment or an exam given in school?
Sudharaka said:
Hi wonguyen1995,
i know that but i think this question is metaphor
Well forget it
Well forget it
I am not quite sure what you mean. My question was a literal one, not metaphorical. Perhaps your earlier question was a metaphor?
In any case, I'm asking my question because it is against MHB policy knowingly to help with graded problems. Now, if the page you posted is from a practice test, there's no issue at all. But if it's from a graded test, then we will need to close this thread.
Sorry. Maybe i think alot. it is the practice test in the previous semester. So can you help me figure out one ?
FAQ: Solve Root of Equation Q1a: Help Here
What is the definition of a root of an equation?
A root of an equation is a value that, when substituted into the equation, makes the equation true. In other words, it is the value that satisfies the equation.
How do you solve for the root of an equation?
To solve for the root of an equation, you can use various methods such as factoring, graphing, or using the quadratic formula. The method used depends on the type of equation and the level of complexity.
What is the difference between real and complex roots?
Real roots are values that are on the real number line and can be graphed on a coordinate plane. Complex roots, on the other hand, involve imaginary numbers and cannot be graphed on a traditional coordinate plane.
Can an equation have more than one root?
Yes, an equation can have multiple roots. For example, a quadratic equation can have two real roots or two complex roots.
How do you check if a value is a root of an equation?
To check if a value is a root of an equation, you can substitute the value into the equation and see if it satisfies the equation. If the equation is true when the value is substituted, then it is a root of the equation.
