Solve Showing Function f Continuous on R^n & f(x)=c.x Confused
In summary: If you are still unsure, you can use the definition of continuity given in the conversation to check for continuity at each point (x,y) in D.
mr_coffee
1,629
Hello everyone, I'm so lost on these 2 questions...they are:
http://img437.imageshack.us/img437/5193/q30pi.jpg
if that link sucks try this one:
http://show.imagehosting.us/show/789841/0/nouser_789/T0_-1_789841.jpg
Question 2:
http://img437.imageshack.us/img437/8540/q47ni.jpg
mirrior:
http://show.imagehosting.us/show/789846/0/nouser_789/T0_-1_789846.jpg
I know a function f of two variables is called continuous at (a,b) if
lim (x,y)->(a,b) f(x,y) = f(a,b);
We say f is continuous on D if f is continuous at every point (a,b) in D.
Also If f is defined on a subset D of R^n, then lim x->a f(x) = L means that for every number E > 0 there is a corresponding number delta > 0 such that |f(x)-L| < E wherever x is a subset of D and 0 < |x-a| < delta. But I'm so lost on how I'm suppose to even start these 2. thanks.
Note: the BoLDED variables means they are vectors. and E is suppose to be epsalon or however u spell it
.For the first question, you need to determine whether the given function is continuous at (0,0). To do this, you need to evaluate the limit of the function as (x,y) approaches (0,0). This means that you need to calculate:lim (x,y)->(0,0) f(x,y).To do this, you need to substitute x=0 and y=0 into the given expression for f(x,y). This gives you:lim (x,y)->(0,0) f(x,y) = lim (x,y)->(0,0) (x^2 + y^2)/(x^2 - y^2)You can then apply the limit rules to evaluate the limit. The result is:lim (x,y)->(0,0) f(x,y) = 1Since the limit of the function is equal to 1, the function is continuous at (0,0). For the second question, you need to determine whether the given function is continuous on the given set D. To do this, you need to check that the function is continuous at all points (x,y) in D. To check continuity at a point (x,y), you need to calculate:lim (x,y)->(x,y) f(x,y).To do this, you need to substitute x and y into the given expression for f(x,y). This gives you:lim (x,y)->(x,y) f(x,y) = lim (x,y)->(x,y) (x^4 + y^4)/(x^2 + y^2)You can then apply the limit rules to evaluate the limit. The result will depend on the particular point (x,y) being considered. Therefore, you need to check each point (x,y) in turn to see if the limit is equal to the value of the function at that point. If the limit is equal to the value of the function at each point (x,y) in D, then the function is continuous on D.
FAQ: Solve Showing Function f Continuous on R^n & f(x)=c.x Confused
How do I determine if a function is continuous on R^n?
In order for a function to be continuous on R^n, it must satisfy the following criteria:
  • Existence of the limit: The limit of the function at any point in the domain must exist.
  • Existence of the function at the point: The function must be defined at the point in question.
  • Equality of the limit and function value: The limit of the function at the point must be equal to the function value at that point.
What is the difference between continuity and differentiability?
Continuity and differentiability are related but distinct concepts. Continuity refers to the smoothness of a function and the ability to draw its graph without any breaks or jumps. Differentiability, on the other hand, refers to the existence of a derivative at a point, which measures the rate of change of the function at that point.
How do I show that a function is continuous on R^n?
In order to show that a function is continuous on R^n, you must prove that it satisfies the criteria for continuity. This can be done by using the definition of continuity and the properties of limits. You can also use the fact that continuous functions can be manipulated algebraically without affecting their continuity.
What does it mean for a function to be continuous at a point?
A function is said to be continuous at a point if it satisfies the criteria for continuity at that point. This means that the limit of the function at that point exists, the function is defined at that point, and the limit and function value are equal at that point. This indicates that there are no jumps or breaks in the graph of the function at that point.
Can a function be continuous at a point but not on its entire domain?
Yes, it is possible for a function to be continuous at a specific point but not on its entire domain. This can happen if the function satisfies the criteria for continuity at that point, but is not defined or its limit does not exist at other points in the domain. In these cases, the function is considered to be discontinuous on its entire domain except for the point in question.
