Solve Simultaneity Problem with Alice & Bob
In summary: It doesn't matter that the light came from a point source. Only...In summary, Alice and Bob can't agree about the simultaneity of flashes at the end of Alice's railroad car. One frame, the right or left moving light went slower or faster than the other which is absurd.
  • #36
rq704c said:
I'm accounting for the time it takes light to reach the ends ot the train sultaneously in Bobs frame from the beam splitter.
Huh? What do you mean "accounting for"? Forget Bob, we're talking about the train frame. Do you agree that the light beams were sent out from a single event? Do you agree that this event took place in the forward end of the train? Then of course the light will take different times to reach the ends of the train according to train observers. It's as simple as that.
  • #37
paw said:
Ok, I accept that. But it's simpler and easier to understand if you don't introduce more and more variables.
This is, I think, the root of the problem. You are seeing the emmision of two photons as a single event. I disagree. The two photons are independant and free to travel different paths. It's not their creation that is of concern to this problem it's the two separate events of their detection that we are discussing. The events of detection are simultaneous in one frame and not simultaneous in the other.
Two photon emission from a single source is common via down conversion. Two photons = one event.
  • #38
It's perfectly OK to consider the emission of both photons as a single event. The main thing is that everyone agrees that the two photons were emitted at the same place and time. (That's not the problem.)
  • #39
No we agreed that Alice did not see the two flashes simultaneously. Bob set the experiment up in such a way that the two photons hit both of her detectors simultaneosuly in his frame. I'm making a picture.
  • #40
You are making this much more complex than it needs to be. Please state whether or not you believe simultaneity is not agreed upon. If you say that is it not, what problem do you have with it?
  • #41
Who needs a picture? If you agree that according to Alice the flashes reach the ends of the car at different times, then what's the problem? (The statement that "Alice did not see the two flashes simultaneously" is ambiguous. It does not mean that she has any reason to think they weren't emitted simultaneously.)
Seems like you are confusing the emission of the photons (which everyone, including Alice, agrees happened at the same time) with their arrival at the ends of the car.
  • #42
Sure, but it's not the creation event we are discussing, it's the two detection events that are of concern.
You can analyse the problem at the level of the creation event but that wasn't the original question. I did try to address the creation event in an earlier post. In that case Bob agreed the photons were created at the same time, Alice did not agree they were created at the same time. A more rigorous analysis would require a quantum explanation which I'm not qualified to give and is really outside the scope of this forum.
  • #43
Seems like we are off on a side road, but if one frame sees two photons emitted at the same time and place, then all frames will. Including Alice's frame.
  • #44
Yes
Yes
The photons are set up by Bob, to force the photons to reach the two detectors simultaneously in his frame, not at different times.
  • #45
Right! So what are we discussing here? They arrive at the detectors simultaneously in Bob's frame, but at different times in Alice's frame. Done!
This thread seems to be going in circles. I suggest you make your point quick.
  • #46
Here's a diagram
  • #47
rq704c said:
Here's a diagram
OK. So?
  • #48
Yeah, I think I could have said that better. I'm thinking of the beam splitter as a black box simply emitting two independant photons with the mechanism hidden. This was in an attempt to show that it's not the creation event we are discussing. It seems like every time I try to give an answer the question changes.
  • #49
I know the feeling. :wink:
  • #50
Doc Al said:
OK. So?
If you look at the right diagram, the two photons hit the two detectors simultaneously in Bob's frame at t = 0. The flashes from the detections then propogate back toward Alice and Bob. If Alice says the signals arrive at her head at different times in her frame, we have to conclude that the two photons were created or emitted at different times because the light time distance is equal from the two detectors back to the beam splitter at t = 0. Thus Alice and Bob diagree that the two photon creation event was a single event.
  • #51
Ah... I finally see what you're talking about. You are concerned with the time that specific observer Alice (in the middle of the train) receives signals from the detectors.
The light travel time from the detectors happens to be equal, but the photons do not arrive at the detectors simultaneously. Alice will deduce that the signals from the detectors were not sent out at the same time. Which makes perfect sense since the original photons had to travel different distances to get to the detectors.
Again: No mystery!
  • #52
In your scenario, if I understand it right, Alice will also agree that the light reaches each detector simultaneously. I know this is not what you are trying to express, though. You need to understand that to a stationary observer, the light needs to travel different distances to reach each part of the train. This is what results in the disagreement.
  • #53
Again: No mystery!
...The photons travel the EXACT SAME DISTANCE to the detectors. Look at the picture again.
  • #54
However in Bob's frame, they travel different distances back to Alices head beacuse she's moving to the right.
  • #55
Look at your own diagram again! In the train frame, the photons travel different distances to the detectors. (The distance would be the same if the photons were emitted at the center of the train, but they are not.)
Which, again, makes perfect sense! Everyone agrees that the signals from the detectors arrive at Alice's head at different times. And since the signals leave the detectors at the same time in Bob's frame, they'd better travel different distances in his frame.
  • #56
Agreed!
  • #57
Wow, 56 posts for one thread in a 3 hour period. That has got to be some kind of record.
  • #58
Yeah that's a lot.
  • #59
ok I am sorry but all your doing is rewording the original problem "if a flash is emitted in the center of the train , one observer will see it hit both ends simultaneously and the other will not" don't try to reword it or change the that scenario, you will only delay your understanding of it. What the scenario is trying to help you understand is that the speed of light is always c to every frame. If your traveling at .5c and you measure the speed of light coming at you from the front it will measure c. if you measure light coming from behind then it will also measure c.. even though you are traveling at .5c already. Also if you emit a beam of light while going .5c you will see it speed off at c and to the stationary observer it will also be going c NOT 1.5c there for the two will argue at the distance the beam traveled from the rocket over a given time... and if you still don't understand... then if you emit a pulse of light while traveling at .5c then u both measure the distace from the rocket the light traveled after one second.. The man in the rocket would say it was 186000 miles from the rocket, and the stationary observer would say it was 93000 miles from the rocket after one second the pulse was emitted ...two people have seen 2 different things and both are true
