MHB Solve sin³(x) - cos³(x) = sin²(x)
  • Thread starter Thread starter anemone
The discussion revolves around solving the trigonometric equation sin³(x) - cos³(x) = sin²(x). Initial attempts involved various algebraic manipulations, including dividing by sin³(x) and applying triple angle formulas, but these approaches did not yield satisfactory results. A more successful method involved rewriting the equation as a polynomial in terms of sin(x), leading to a quartic equation that provided one obvious root, sin(x) = 1, corresponding to x = π/2. Further analysis revealed two additional real solutions, approximately x = 1.12765 and x = 3.76342, although the latter required quadrant adjustments for accuracy. The discussion concluded with a note on the difficulty of finding exact solutions, suggesting the problem may originate from a trigonometry textbook.
anemone
MHB
POTW Director
Hi MHB,
This seemingly very simple and straightforward trigonometric equation (Solve for x for which sin³x-cos³x=sin²x) has me stumped! I am fretting after I exhausted all kind of tricks that I could think of (which I will mention in my attempts next) trying to attempt the problem and now, I wanted so much to ask for help here at MHB!
First attempt:
I first divided through the equation by sin³x, bearing in mind sin³x≠0 and obtained:
$$1-\cot^3x=cscx$$
$$(1-\cot^3x)^2=\csc^2x$$
$$(1-\cot^3x)^2=1+\cot^2x$$
If l let $$ \cot x=k,$$ the equation above becomes $$(1-k^3)^2=1+k^2$$ and this is a futile attempt to say the least.
Second attempt:
I applied the triple angle formulas for both sine and cosine to the given equation and ended up with
$$\frac{3\sin x-\sin 3x}{4}-\frac{\cos3x+3\cos x}{4}=\sin^2x$$
$$3\sin x-\sin 3x-\cos 3x-3\cos x=2(2\sin^2x)$$
$$3(\sin x-\cos x)-(\sin3x+\cos3x)=2(1-\cos2x)
This is another unwise substitution to make, knowing it can hardly bring us any closer to the answer...
Anyway, this is how I approached it.
$$3( \sin x- \cos x)-(\sin3x+\cos3x)=2(1-\cos2x)$$
$$3\sqrt{2}\sin(x-\frac{\pi}{4}-\sqrt{2}\sin(3x+\frac{\pi}{4})=2(1-\cos 2x)$$ I stopped right at this point, because we can tell this is a very bad move...
Third attempt:
$$\sin^3 x-\cos^3 x=\sin^2 x$$
$$\sin^2 x(\sin x-1)=\cos x\cos^2 x=\cos x(1-\sin^2 x)=\cos x(1+\sin x)(1-\sin x)$$
$$\sin^2 x(\sin x-1)-\cos x(1+\sin x)(1-\sin x)=0$$
$$\sin^2 x(\sin x-1)+\cos x(1+\sin x)(\sin x-1)=0$$
$$(\sin^2 x+\cos x(1+\sin x))(\sin x-1)=0$$
$$(\sin^2 x+\cos x+\sin x\cos x))(\sin x-1)=0$$
and obviously $$\sin x=1$$ is an answer to the problem.
And now, all kind of thoughts enter my mind, I am not even sure when we have the case ab=0, if a=0 is imminent and true, then b isn't necessary a zero. And everything seems to reach an impasse after getting sinx=1 as one of the answers to the problem.
So, I decided to factor the LHS of the given equation and see how far I can go with this approach...
$$(\sin x-\cos x)(\sin^2 x+\sin x\cos x+\cos^2 x)=\sin^2 x$$
$$(\sin x-\cos x)(1+\sin x\cos x)=\sin^2 x$$
and it's also safe to say at this juncture this won't work out well and I am at my wit's end to solve this problem.
I would appreciate it if someone could offer me some hints to solve it.
Thanks.
Mathematics news on Phys.org
Re: Solve sin³x-cos³x=sin²x
Hello
This is how I did it. We have,
\[ \sin^3x - \cos^3 x = \sin^2 x \]
Write this as the following.
\[ \sin^3x-\sqrt{(1-\sin^2x)}\;(1-\sin^2x) = \sin^2x \]
Here let \( t = \sin x\), and then rearranging the terms we get a polynomial in t.
\( (t^3 - t^2)^2 = (1-t^2)^3 \). Expanding this we have,
\[ 2t^6 - 2t^5 - 2t^4 + 3t^2 - 1 = 0 \]
Now using the rational root theorem and synthetic division, we can arrive at \( (t-1)^2 \) as
one factor. So obviously \(t=1\) is one root. The remainder polynomial equation then is
\[ 2t^4+2t^3 - 2t -1 = 0 \]
This is a quartic equation, for which there are known solutions. For this equation there
are two real and two imaginary solutions. The real solutions are \(t = 0.903408 \) and
\(t = -0.582522 \). Plugging back in the original equation for \( \sin x\), we can solve for \(x\).
\( x = 1.12765 \) and \( x = 3.76342 \), also the first solution of \( t=1 \) leads to \( x = \frac{\pi}{2}\).
So three solutions are \(x = 1.12765\;\;x = 3.76342\;\;x = \frac{\pi}{2} \)
IssacNewton said:
Hello
I think you need to add \(+ 2\pi k\) where \(k\in\mathbb{Z}\) since there are infinitely many solutions for each principle argument.
I am assuming that \( x \in [0,2\pi] \)
IssacNewton said:
Hello
I agree with the solutions $x = 3.76342$ and $x = \frac{\pi}{2}$, but not with $x = 1.12765$. The reason is that when going from $\sin x$ to $x$ you need to ensure that you choose the angle in the correct quadrant. When you check against the original equation $\sin^3x - \cos^3x = \sin^2x$, you find that both solutions $\sin x = 0.903408$ and $\sin x = -0.582522$ require $\cos x$ to be negative. So in both cases you need to have $x$ in the interval $\bigl[\frac\pi2,\frac{3\pi}2\bigr]$. Therefore the solution is not $x = 1.12765$ but $x = \pi - 1.12765 = 2.01394$.
Ideally, it would be far better to have an exact solution rather than these numerical approximations. But I am not convinced that that can be done for this problem.
Opalg, thanks for pointing mistake. I did the math in hurry.
Since you are from UK, you must have heard of S.L. Loney who did write a book
on trigonometry. I think this problem could be from that book.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
