MHB Solve Sum of {30 \choose i} with Binomial Theorem
The discussion focuses on simplifying the sum $$\sum_{i=0}^{30} \frac{1}{i+1} {30 \choose i}$$ using the binomial theorem. It is established that this sum can be expressed in sigma notation, leading to the formulation $$S=\frac{1}{n+1}\sum_{k=0}^{n+1} {n+1 \choose k} - \frac{1}{n+1}$$. By applying the binomial theorem, the sum simplifies to $$S=\frac{2^{n+1}-1}{n+1}$$. Additionally, integrating the binomial theorem yields a similar result, confirming the validity of the approach. The final expression for the sum is thus $$S=\frac{2^{31}-1}{31}$$ when substituting \( n = 30 \).
mathgirl1
Simplify (find the sum) of $${30 \choose 0} + \frac{1}{2}{30 \choose 1}+ \frac{1}{3}{30 \choose 2} + ... + \frac{1}{31}{30 \choose 30}$$.
Do this is two ways:
1. Write $$\frac{1}{i+1}{30 \choose i}$$ in a different way then add
2. Integrate the binomial thorem (don't forget the constant of integration)
I know the Bionomial Theorem is $$(x+y)^n = \sum_{k=0}^{n} {{n \choose k}x^ky^{n-k}}$$. So obviously I have y=1 and n=30 but I don't know how to convert $$\frac{1}{1+i}$$ into the form $$x^k$$or $$y^{n-k}$$ for all values of k. Can anyone help with this? I'm sure if I can figure out how to write it in the form I need then I can compute the sum using $$(x+y)^n$$ and then integrate this but need some help. Any help is much appreciated. Thank you!
I know that $$x=(k+1)^{\frac{-1}{k}}$$ but I don't know how to use this to compute $$(x+y)^n$$ since x is in terms of k and not in terms of x. Help please! I am sure this should be simple but I am stuck
Let's look at the first part of the problem...and let's generalize by using $n$ instead of 30:
I think I would begin by writing the sum $S$ using sigma notation:
$$S=\sum_{k=0}^{n}\left(\frac{1}{k+1}{n \choose k}\right)$$
Now, if we use the definition:
$${n \choose r}\equiv\frac{n!}{r!(n-r)!)}$$
We may write:
$$S=\sum_{k=0}^{n}\left(\frac{1}{k+1}\cdot\frac{n!}{k!(n-k)!}\right)$$
And then:
$$S=\frac{1}{n+1}\sum_{k=0}^{n}\left(\frac{(n+1)!}{(k+1)!((n+1)-(k+1))!}\right)$$
And then:
$$S=\frac{1}{n+1}\sum_{k=1}^{n+1}\left(\frac{(n+1)!}{k!(((n+1)-k)!}\right)$$
And then:
$$S=\frac{1}{n+1}\left(\sum_{k=0}^{n+1}\left(\frac{(n+1)!}{k!((n+1)-k)!}\right)-1\right)$$
And then:
$$S=\frac{1}{n+1}\left(\sum_{k=0}^{n+1}\left({n+1 \choose k}\right)-1\right)$$
Can you continue by applying the binomial theorem?
To follow up, we have:
$$2^n=(1+1)^n=\sum_{k=0}^{n}\left({n \choose k}1^{n-k}1^{k}\right)=\sum_{k=0}^{n}\left({n \choose k}\right)$$
Thus, there results:
Now, if we begin with the binomial theorem:
$$(1+x)^n=\sum_{k=0}^{n}\left({n \choose k}x^{k}\right)$$
And then integrate both sides w.r.t $x$, we obtain:
$$\frac{(1+x)^{n+1}}{n+1}+C=\sum_{k=0}^{n}\left({n \choose k}\frac{x^{k+1}}{k+1}\right)$$
To solve for the constant of integration $C$, let's use $x=0$:
$$\frac{(1+0)^{n+1}}{n+1}+C=\sum_{k=0}^{n}\left({n \choose k}\frac{0^{k+1}}{k+1}\right)$$
And from this, we obtain:
$$C=-\frac{1}{n+1}$$
Hence:
$$\frac{(1+x)^{n+1}-1}{n+1}=\sum_{k=0}^{n}\left({n \choose k}\frac{x^{k+1}}{k+1}\right)$$
And then letting $x=1$, we have our result:
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
