Solve System of Equations: 4x^2+25y^2+9z^2-10xy-15yz-6xz=0
In summary, a system of equations is a set of equations with unknown variables that are meant to be solved simultaneously using algebraic methods such as substitution or elimination. The purpose of solving a system of equations is to find the values of the unknown variables that satisfy all of the given equations, allowing for a better understanding of the relationships between the variables and the overall problem. The solution to the equation 4x^2+25y^2+9z^2-10xy-15yz-6xz=0 is an infinite set of ordered triplets (x, y, z) due to the presence of multiple unknown variables and only one equation. Systems of equations can also be solved using technology, but it is important to have a
kaliprasad
MHB
1,335
Solve the system of equations
$4x^2+25y^2 +9z^2 - 10xy -15yz - 6xz = 0\cdots(1)$
$x+y+z=5\cdots(2)$
Mathematics news on Phys.org
$x+y+z=5\cdots(2)$
my solution:
rearrange (1) we have :
$2x(2x-5y)+5y(5y-3z)+3z(3z-2x)=0--(3)$
for any $2x=5y=3z, (3)$ will be zero
so we have :$x:y:z=15:6:10---(4)$
from $(2)$ we have :$x=\dfrac{75}{31},y=\dfrac{30}{31},z=\dfrac{50}{31}$
Albert said:
my solution:
Above is a right solution. kindly find other solutions or prove that no other solution exists
$x+y+z=5\cdots(2)$
$(1)\times 2$ we have:
$8x^2+50y^2+18z^2-20xy-30yz-12zx=0$
or $(2x-5y)^2+(5y-3z)^2+(3z-2x)^2=0$
$\therefore 2x=5y=3z$ must hold
$x+y+z=5\cdots(2)$
The first equation is a quadric.
The first step is to analyze it and categorize it.
Let:
$$A = \begin{bmatrix}4& -5 & -3 \\ -5 & 25 & -15/2 \\ -3 & -15/2 & 9 \end{bmatrix}$$
Then (1) can be written as:
$$\mathbf x^T A \mathbf x = 0$$
$A$ is a real symmetric matrix, meaning it is diagonalizable with real eigenvalues and an orthonormal set of eigenvectors.
Its characteristic equation is:
$$\lambda^3 - 38\lambda^2 + \frac{1083}{4}\lambda = 0$$
This implies we have eigenvalues $\lambda_1 = 0$, and $\lambda_2, \lambda_3 > 0$.
So:
$$\mathbf x^T A \mathbf x = \mathbf x^T B^T \begin{bmatrix}0& 0 & 0 \\ 0 & \lambda_2 & 0 \\ 0 & 0 & \lambda_3 \end{bmatrix} B \mathbf x = 0$$
where $B$ is an orthogonal matrix formed by the corresponding eigenvectors.
Consequently, we're looking at a degenerate quadric that is similar to:
$$\lambda_2 (y')^2 + \lambda_3 (z')^2 = 0$$
This is a line through the origin, since $\lambda_2, \lambda_3 > 0$.
The direction of the line is given by the eigenvector for $0$, and the line is also the kernel of $A$.
Solving $A\mathbf x=0$, we find:
$$\mathbf x = t\begin{pmatrix}15 \\ 6\\ 10\end{pmatrix}$$
Combining with (2) tells us that:
$$x=\frac{75}{31},y=\frac{30}{31},z=\frac{50}{31}$$
Just like Albert found. ;)
FAQ: Solve System of Equations: 4x^2+25y^2+9z^2-10xy-15yz-6xz=0
What is a system of equations?
A system of equations is a set of two or more equations with multiple unknown variables that are meant to be solved simultaneously.
How do you solve a system of equations?
To solve a system of equations, you must use algebraic methods such as substitution or elimination to find the values of the unknown variables that make all of the equations true.
What is the purpose of solving a system of equations?
What is the solution to the equation 4x^2+25y^2+9z^2-10xy-15yz-6xz=0?
The solution to this equation is an infinite set of ordered triplets (x, y, z) that satisfy the given equation. This is because there are three unknown variables and only one equation, so there are multiple possible solutions.
Can systems of equations be solved using technology?
Yes, systems of equations can be solved using technology such as graphing calculators or online solvers. However, it is important to understand the underlying concepts and methods of solving systems of equations instead of solely relying on technology.
