Solve System of Equations with Real Numbers
In summary, the conversation discusses solving a system of equations in real numbers with a given set of expressions. The participants suggest that (3,3,3) may be a solution and discuss the symmetry of the equations. The conclusion is that x = y = z = 3 is a possible solution, but symmetry does not guarantee it as the only solution.
juantheron
247
Solve the following system of equations in real numbers:$\sqrt{x^2-2x+6}\cdot \log_{3}(6-y) =x$$\sqrt{y^2-2y+6}\cdot \log_{3}(6-z)=y$$\sqrt{z^2-2z+6}\cdot\log_{3}(6-x)=z .$
Have you looked at (3,3,3) being a solution, not sure myself but it might work given the base of those logs.
Hello, jacks!
I agree with pickslides . . .
[tex]\text{Solve the following system of equations in real numbers:}[/tex]
. . [tex]\begin{array}{ccc}\sqrt{x^2-2x+6}\cdot \log_{3}(6-y) &=&x \\
\sqrt{y^2-2y+6}\cdot \log_{3}(6-z) &=& y \\
\sqrt{z^2-2z+6}\cdot\log_{3}(6-x)&=&z\end{array}[/tex]
Due to the symmetry, I assume that [tex]x = y = z.[/tex]
Then we have: .[tex]\sqrt{x^2-2x+6}\cdot \log_3(6-x) \:=\:x[/tex]
By inspection, we see that: .[tex]x\,=\,3.[/tex]
soroban said:
Hello, jacks!
Symmetry only guarantees that any permutation of the values of x, y, z for a solution is also a solution.
Obviously x=y=z=3 is a solution, but symmetry alone does not force us to conclude that it is the only solution.
CB
FAQ: Solve System of Equations with Real Numbers
What is a system of equations?
A system of equations is a set of two or more equations that contain the same variables. The solutions to the system are values that make all of the equations true.
What are real numbers?
Real numbers are numbers that can be found on the number line. They include all rational and irrational numbers, such as integers, fractions, decimals, and square roots.
How do you solve a system of equations with real numbers?
To solve a system of equations with real numbers, you can use various methods such as substitution, elimination, or graphing. These methods involve manipulating the equations to eliminate one variable, and then solving for the remaining variable.
Why is it important to solve systems of equations with real numbers?
Solving systems of equations with real numbers allows us to find the values of the variables that make the equations true. This can be useful in many real-world situations, such as finding the optimal solution to a problem or determining the intersection point of two lines.
Can a system of equations have infinite solutions?
Yes, a system of equations can have infinite solutions if the equations are equivalent or if they represent the same line on a graph. In this case, any value for the variables will make the equations true.
