MHB Solve System of Equations: X^2+y^2 and (x+3)^2+(y-3)^2=9
The discussion focuses on solving a system of equations represented by two circles, X^2 + y^2 = 9 and (x + 3)^2 + (y - 3)^2 = 9. Participants suggest both algebraic and geometric methods for finding the intersection points of the circles. A geometric approach involves analyzing the distance between the circle centers and their radii to determine the number of solutions. The midpoint between the circle centers is also highlighted as a key point for finding solutions along a perpendicular line. Ultimately, both algebraic and geometric strategies can effectively yield the intersection points of the given equations.
ironluis
I need your help for solved this. :confused:
X^2+y^2=9
(x+3)^2+(y-3)^2=9
Please help me.
Mathematics news on Phys.org
Re: I need help!
Hi ironluis,
Welcome to MHB! (Wave)
Is this a question about systems of equations? Are you supposed to look at the two equations and solve for $x$ and $y$? This can be done algebraically however you posted the question in our geometry forum. Are you supposed to solve it geometrically?
Im sorry :confused:
Notice both equations are equal to 9, so they are equal to each other. Set them equal to each other, expand, simplify...
A more geometric approach would be to consider the point midway between the center of the circles. We use the mid-point in this case because the radii of the circles is the same. If the distance of this midpoint to the radii is greater than the radii, then there is no solution. If this distance is equal to the radii, there is one solution, and if it is less than the radii, and greater than zero, then there are two solutions. If the distance is zero, then the circles are concurrent and there are an infinite number of solutions.
Next, compute the slope of the line segment connecting the center of the circles, and observe that the solutions will lie along the line perpendicular to this segment, and passing through the mid-point of the centers.
This line will give you the result suggested by Prove It's much more straightforward algebraic approach.
Then you want to find the points on this line which satisfy either of the equations describing the circles.
Hi,
I think the best geometric solution to the problem of intersection of two circles is given at Circle, Cylinder, Sphere
I have used this algorithm with good success.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
